what diff to use
bumper
State: TAS
what diff to use
Post by bumper »
my dads putting a 253 in his fb sedan, not quite sure what diff to use :?:
was thinking of putting a lh diff in but it is over all 15mm longer, would this matter :?:
cheers guys :D
FB MAD
Post by FB MAD »
Try LC/LJ Torana diff assembly.There is mention of it somewhere ( I think) as it is a bit shorter than FB/EK diff housing.
I'll leave the rest of the info to those here who have done it.
I would stick to a HR diff, the old banjo can take a fair bit, and there cheep to replace anyway (compared to your 9inch), unless money no option :wink: , Trev 8) .
FB MAD
Post by FB MAD »
Yep,
I've had red motor 2.78 banjo in a HQ 308/T400 no problems, even used 6 cyl rear uni joint ( not V8 uni joint).
Also 253/Trimatic in a UC Torana with red motor banjo 2.78 gears fitted in the UC Salisbury diff ( banjo and UC salisbury gears will interchange) again, no problems.
Didn't abuse them ( read old farts speed here) and never had a problem with them.
Anything is breakable given enough stresses beyond engineered capability but the old banjo centre,like Trev said,will take a bit more than people think.
FB/EK's are relatively light bodied ( close to the same weight as LC/LJ Torana) and this helps as well.
oldnek
Post by oldnek »
Fit a Toyota Supra IRS in it, Piece of Piss :? :roll: :lol:
I did!.... handles fantastic.........
Malcolm
what diff to use
Post by Malcolm »
What holden had the 2.78 ratio :?:
Malcolm W.
bumper
State: TAS
Post by bumper »
thanks allot for your help guy's :lol:
FB MAD
Post by FB MAD »
Quite a few Malcolm as far as I know.
Forum member Dr Terry would know what model they first brought the 2.78 ratio out in.
From memory they were an optional ratio in LC/LJ Torana's and possibly HT and HG as well I guess.Happy to be corrected if this isn't right.
Not sure how long the 2.78 option ran for but again Dr Terry would know.
