Moderators: reidy , Blacky
mez
Posts: 299 Joined: Tue Feb 12, 2008 3:55 pm
Post
by mez » Wed Apr 30, 2008 8:37 pm
i was looking on the net and found this fuel sender
out of a 54 chev sedan i looked just like a early holden
one so i got it from the states $39 the bolt pattern fits perfect
it fits in the tank and moves the gauge when hooked up
(even seem to read correct)do all you guys know of this
(and not let me in on it)as in australia ive found it near impossible to find one
carpe dero
ek61
Posts: 1419 Joined: Sun May 29, 2005 10:09 pm
Post
by ek61 » Wed Apr 30, 2008 8:55 pm
great score
if it fits n does the job its got to be good
were there more available or just the one?
cheers dave
***just cruise***
mez
Post
by mez » Wed Apr 30, 2008 8:59 pm
ek61 dime a dozen on usa ebay
carpe dero
MINT62
Posts: 840 Joined: Sat Aug 05, 2006 8:52 am
Post
by MINT62 » Wed Apr 30, 2008 9:17 pm
great advice mez
i eventually scored an original sender and had it recoed
theres a lot of U.S GM gear that looks like it would suit fb/eks
cheers for that
INVEST IN PRECIOUS METAL
Posts: 14246 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Thu May 01, 2008 8:43 am
How accurate is it Mez? You might have just solved one of those little dramas that plagues virtually every rebuild !
blue ute
Posts: 595 Joined: Mon Nov 14, 2005 11:27 pm
Post
by blue ute » Thu May 01, 2008 9:43 am
This is a good site for a lot of stuff that could be usefull
http://www.fillingstation.com
Post
by Blacky » Thu May 01, 2008 9:52 am
Have bought a bit of gear for my `64 off the Filling Station -good people to deal with and they post with USPS so the freight is reasonable.
Dave
Posts: 107 Joined: Mon Nov 14, 2005 4:53 pm
Post
by Dave » Thu May 01, 2008 9:54 am
I got one from the states that bolted straight up but the float arm had to be a lot shorter than shown in your picture to fit in the tank.
Can you post a close up of the bolted up end so I can see if it is vertical or horizontal design. The one I got was vertical and that was the problem.
My Band.....
www.myspace.com/thesuperdextas
Post
by Devilrod » Thu May 01, 2008 1:04 pm
To the best of my knowledge GMH used a bit of mid fifties Chev stuff. Have a look at the speedo in a 53 Chev, near identical to an FC, same with all the handles. So I'm not surprised that it works Mez. Just never thought to go down that route. Good stuff!
mez
Post
by mez » Thu May 01, 2008 8:05 pm
hey dave im in melbourne at the moment but i will when i get home the sender from what i know is a top tank mounted sender like a fb/ek
carpe dero
Post
by Devilrod » Thu May 01, 2008 8:36 pm
Hey Mez, you should have organized a catch up! How much longer are you down here? Oh yeah which part of Melbourne are you in?
Dave
Post
by Dave » Fri May 02, 2008 10:08 am
sounds good if its top mounted it should be right as long as its 0-30 ohms.
Would be easy to adjust if its not reading right too being top mounted.
How can I get one? Mine is sorting of working but its very touchy having such a short float arm, it fluctuates a lot.
My Band.....
mez
Post
by mez » Sat May 03, 2008 11:31 am
dave it is a 30 ohm one
just look on the usa ebay there will be few on there
carpe dero
Malcolm
Posts: 709 Joined: Tue May 23, 2006 8:20 am
Post
by Malcolm » Sat May 03, 2008 7:38 pm
Does anyone know where I can get a sender to fit my XB thank that will be compatible with the FB dash guage???
Malcolm W.
Post
by Blacky » Sat May 03, 2008 11:24 pm
Probably easier to get another fuel guage,take it to an instrument maker and have it rewound to suit the sender Malcolm.
