engine immobilizer
Malcolm
engine immobilizer
Post by Malcolm »
hey all,
Does anyone know anything about wiring of aftermarket engine immobilizers to commodore ECU :?:
Malcolm W.
ipg
Post by ipg »
hi mal,
there are a couple of points this can be done.
ignition or fuel pump circuits or both.
Malcolm
engine immobilizer
Post by Malcolm »
With the unit I have the instructions say for the wire that goes to the computer, you connect the end of the circit tester to this wire that goes to the computer and then just stab each wire that goes to the computer until you find one that makes the circit tester glow and the engine run rough or stall. Did that and I found 2 wires that just make the engine stall straight up. Tried both wires and neither work when all the rest of the wiring is completed :twisted: :evil:
Malcolm W.
rosco
Post by rosco »
Hi Malcolm - I know we only have "good" people on this forum - and all the "visitors" are also "good people".................... think you understand - probably pm's are more secure...............
sorry if I am offending....
