Clay’s Wedgewood Blue FB Ute
Thanks Mick. Might have to look in to it. I’ve seen it on other cars.
Got all the rubber in place ready to flip over and put it on the ute. Image
I added a couple of corner trims in “keep left sign” sheet, formerly my radiator shroud.
Got my mate Simon to help me put the canopy on the ute. Well, the thing is out the way for now. Doesn’t really gel with the boy racer theme. Image
Cool sthikkers but…
Yeh…… nah!
Glad to see I’m not the only one who has a piece of cardboard handy for the Ute 🤔
Canopy having some retraining while sitting up on the hoistImage
Good Friday job. I made up new hold down bolts for the canopy. Image
It had not had a run since I placed the canopy on some time ago, so went for a careful spin around town, not even getting out of second gear.
Started tidying up the aluminium trims and timber with this plastic wheel. Image
I’m actually digging the brushed look. Image
If it’s fine I’ll take if to coffee and cars on Sunday.
I would have thought the cats and dogs weather the prefered test for leaks Clay.
Better make sure shes glued down, especially with the long haul coming up.
It is basically a sieve Greg. Will be in Elle’s sedan again as it is comfier than the ute. The canopy is very much a summer only option.
Backed into a lighting column at the local coffe and cars last Sunday and put a fair dent in the spare wheel door.
Errol62 wrote: Wed Apr 08, 2026 9:45 pm Backed into a lighting column at the local coffe and cars last Sunday and put a fair dent in the spare wheel door.
Bugger. Not the easiest part to find :roll: :!: :(
Is it repairable at home?
I’m in the midst of repairing the thing. It is full of bog. Need some Wedgewood blue paint, which makes me think closed door respray.
world of pain without tapatalk
Bugger :wtf: :wtf: :cry: :cry:
60Special
Post by 60Special »
Ouch Clay. I solved the problem of the spare wheel door on my PV.
If you remember I did the same on Frank :roll: :roll: :roll:
