Clay’s Wedgewood Blue FB Ute
It is staying as is Harv, though I did run a file around the cover gasket face for a better seal.
Thanks Rob. I can give it a bit more clearance at rhe pedal now m confident it is letting go before I hit the floor with the pedal.
I got a proper tachometer from one of the Torana boys, bit the bullet, and drilled a couple of big holes in the dash. Works like it should. The cheap one I had was jerky, then just stopped working.![Image](//uploads.tapatalk-cdn.com/20240205/dec83dc0c68a5ed2c948ba3d8aeff5bc.jpg)
![Image](http://uploads.tapatalk-cdn.com/20240205/dec83dc0c68a5ed2c948ba3d8aeff5bc.jpg)
6200rpm bit ambitious mate ![](http://emoji.tapatalk-cdn.com/emoji1787.png)
Should get there no problem - at least once
![Big Grin :ebiggrin:](./images/smilies/icon_e_biggrin.gif)
Bahhhhhhh
It'll get there if he leaves the switch at the back set on "8" instead of "6"
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
On "8" you'll be struggling to reach 4000.
Nope, set the switch to "4" instead.
I think some of you may
have confused this with the pissed idiots thread![](http://emoji.tapatalk-cdn.com/emoji1787.png)
95mph in second should get me there![](http://emoji.tapatalk-cdn.com/emoji6.png)
Hey… I’m sober. The idiot part you are probably right about though… I have the attention span of a goldfish and am easily distracted ![🤪](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f92a.svg)
Your eloquence belies that Harv
Can’t go wrong with the Smiths tacho, they look the part and are the right era. ![Thumbs Up :thumbsup:](./images/smilies/icon_thumbup.gif)
Seems to work very well Stephen![Image](//uploads.tapatalk-cdn.com/20240206/85eb4be0c436dd09504765ecf03be42c.jpg)
![Image](//uploads.tapatalk-cdn.com/20240206/32f7fc178f440b74e6132e8d9e9026cc.jpg)
![Image](http://uploads.tapatalk-cdn.com/20240206/85eb4be0c436dd09504765ecf03be42c.jpg)
![Image](http://uploads.tapatalk-cdn.com/20240206/32f7fc178f440b74e6132e8d9e9026cc.jpg)
Finally changing the head over. Here are the plugs. No 1 to the right.![Image](//uploads.tapatalk-cdn.com/20240216/445400eaa7a067a5528a5a7455e51f8f.jpg)
![Image](//uploads.tapatalk-cdn.com/20240216/52fa13f13cdbaa64ec4e5707e4b2910e.jpg)
I may have damaged some of the valve stem seals when fitting softer springs. Hopefully that accounts for some oiliness on no 2 particularly.
![Image](http://uploads.tapatalk-cdn.com/20240216/445400eaa7a067a5528a5a7455e51f8f.jpg)
![Image](http://uploads.tapatalk-cdn.com/20240216/52fa13f13cdbaa64ec4e5707e4b2910e.jpg)
Might be the lighting in the photos, but 3, 5 and 6 look lean.
