Clay’s Wedgewood Blue FB Ute
It is staying as is Harv, though I did run a file around the cover gasket face for a better seal.
Thanks Rob. I can give it a bit more clearance at rhe pedal now m confident it is letting go before I hit the floor with the pedal.
I got a proper tachometer from one of the Torana boys, bit the bullet, and drilled a couple of big holes in the dash. Works like it should. The cheap one I had was jerky, then just stopped working.Image
gledge
Post by gledge »
6200rpm bit ambitious mate
gledge wrote: Mon Feb 05, 2024 5:47 pm 6200rpm bit ambitious mate Image
Should get there no problem - at least once :ebiggrin: :ebiggrin:
Bahhhhhhh
Blacky wrote: Mon Feb 05, 2024 7:00 pm
It'll get there if he leaves the switch at the back set on "8" instead of "6" :mrgreen:
On "8" you'll be struggling to reach 4000.
Nope, set the switch to "4" instead.
I think some of you may
have confused this with the pissed idiots thread
95mph in second should get me there
Hey… I’m sober. The idiot part you are probably right about though… I have the attention span of a goldfish and am easily distracted 🤪
Your eloquence belies that Harv
Can’t go wrong with the Smiths tacho, they look the part and are the right era. :thumbsup:
Seems to work very well StephenImageImage
Finally changing the head over. Here are the plugs. No 1 to the right.ImageImage
I may have damaged some of the valve stem seals when fitting softer springs. Hopefully that accounts for some oiliness on no 2 particularly.
Might be the lighting in the photos, but 3, 5 and 6 look lean.
