Red Rattler Revamp
Re: Red Rattler Revamp
Then filled in the gaps
Then put the work light in the boot to find the bits I missed and zapped them up
Close enough- seam sealer and body schutz will hide the rest
Buzzed up the last of it then had a look above to tidy up the spiders legs
Last bit was replace this little section - did a bit of CAD work first
Then cut a bit of tin and clamped it up ready for the glue gun
Zapped up , buzzed the dags off and called it done Image
funkyscooter
Post by funkyscooter »
Nice one Blacky. Finding pin holes with the work light is a blessing and a curse. Just when you think you are done you grind and find another. Or move the light and reveal even more.
Scott
The trick is to know when to stop looking 🤣🤣👍
That’s how it’s done mate. Excellent progress.
Its a curse, I can't leave it alone until no holes are left.
500 x times glasses and months of practice solves these holey issues !!
Also I find more heat with quick blasts and weld on top of the previous spot half overlapped, like i said months of practice !!!!!!!!
It is coming together although Blacky.
Gotta love CAD (Cardboard Assisted Drawing) 🤔🤣🤣🤣😝😝
Bit more today , back on the wires again, not my favourite job
Fitted a deutsch plug to the TPS after having no luck finding a replacement plug to suit -
Then sorted out the radiator hoses - both need a joiner midway , bottom one is 2 separate hoses and top one is a single hose that was the right shape but too short
Then onto the bonnet hinges, they were never quite right, the main issue was that they fouled on the subframe drip rails so we made spacers to bring them in a bit which meant the holes didn’t line up so a mod was required
Got it working sort of properly
On and off a dozen times or more, close enough now to take the hinges to work for blasting and order some 5/16UNF nutserts
top join looks perfect for a TEFBA filter
Mick wrote: Mon Aug 28, 2023 8:33 pm top join looks perfect for a TEFBA filter
Good idea Mick , when I pulled the radiator hose off it was full of crap and its a freshly built motor with a new water pump, radiator and hoses ........ :wtf:
melly
Post by melly »
Good progress Blacky- what type of hinges are they mate and how are they snubbed? looks like a setup like that could fix my fouling issues?
melly
Post by melly »
Sorry mate now I look closer I can see the pins for gas strut attachments.
