FB Standard Wagon
Re: FB Standard Wagon
FbSTDwagon wrote: Wed Apr 20, 2022 8:11 pm
In the Shed wrote: Tue Apr 19, 2022 11:25 am Nice Drew,
So for the record what has been done to that head. Can I see double valve springs and bigger valves?
Hi Stephen.
Not 100% sure what’s has exactly been done but it’s a HSD head so they go over from top to bottom.
What I do know is.
Hot tanked and crack tested
Modern valve stem seals
New springs, retainers and big valves
Ported to their own specs
Decked to hell, definitely no thumb print to be seen
Should be a good head for the combo I’m building
👍 can’t wait to see it come together
FbSTDwagon
Post by FbSTDwagon »
Just having a potter about the shed and thought I’d have a look at the wagons rear deck covering the spare wheel.
I will buy some new marine ply and fit it all up.
However I am short one of the steel ‘runners’ which screws to the deck which are unique to the 219 STD wagon. I have a special wagon out the front and the deck in that is covered in vinyl.
Would anyone have a ‘runner’ the are prepared to part with?
480 mms is the length I need.
Happy to pay.
Drew
gpi
Post by gpi »
looks like a previous owner was being creative, so i think youve not accounted for that.
they should all be the same size on each board - i think the short ones on the small board are for the tailgate
FbSTDwagon
gpi wrote: Fri Apr 22, 2022 11:22 am looks like a previous owner was being creative, so i think youve not accounted for that.
Ahh cheers for the info, I have had another look and I think the smaller deck is correct for the runners as per the photo and yes I did get mixed up for which runner I need for the larger deck.
I actually need 1 of the lager runners at 530 mm long.
Drew
FbSTDwagon
Also chasing a head light chrome ring and the 3x tiny screws if any one has one they would like to sell.
Drew
gpi
Post by gpi »
I should have headlight bits Drew
Checked the stash, I have a 480mm one, but no long ones.
FbSTDwagon
Harv wrote: Fri Apr 22, 2022 5:05 pm Checked the stash, I have a 480mm one, but no long ones.
Thanks for checking Harv, I’m on the home straight now in regards to all the bits and bobs needed.
Its a good feeling knowing all I have to chase up are the finishing touches.
Drew
FbSTDwagon
Errol62 wrote: Fri Apr 22, 2022 4:45 pm I should have headlight bits Drew
Clay I seem to have overlooked your post.
Yes I’d take you up on the offer if you have what I need thanks
Drew
Yeah mate I’ve got a box of Lucas lights here you can rummage through, me being a Bosch man now ,heh, heh.
FbSTDwagon
Mick wrote: Thu Mar 17, 2022 9:09 pm
FbSTDwagon wrote: Thu Mar 17, 2022 7:49 am
Mick if your interior light is complete just leave it complete mate, no need to strip a small part out and then be holding a light that don’t work.
you can have the whole lot if you want it just send postal address
275466520_337830998294949_6744427929200123281_n.jpg275770092_333048715518340_7617179050590046958_n.jpg
I relieved a gift in the post from Mick in Coffs Harbour in the form of an interior light.
Thanks Mick!
So I finally got around to looking at it today at it a nice complete unit which has the little fork and spring so it all works.
Went to remove the bulb and the thin Bakelite pice broke so it looks like it be making 1 out of the 2
Micks spring an fork will go into my original unit
Drew
FbSTDwagon
Nice complete interior light.
It’s funny how the smallest parts are the ones that sometime bring you undone!
Drew
FbSTDwagon
And Clay was nice enough to fix me up with a chrome headlight ring and the 3 micro screws.
Much appreciated mate.
He even gave me a Lucas headlight as I was one short, only to get home and find the one 1 have got is cracked!
Calling Clay, calling Clay hahaha
Drew
Drew,
How much of a hurry are you in? I have a few Lucas headlight bodies.
And also, for things like this, Anthony Pearson (the Classic Bulbs guy) is worth getting in touch with.
