Clay’s Wedgewood Blue FB Ute
Tidied up the shed and started fitting the roller rockers today
Yes Brett, standard 3/8” press in, standard 1.5 ratio, standard pushrods. It’s a mild duration 214* with 0.429” lift, similar to X2 spec. Springs to suit.
They weren’t easy to come by but Wyse Industries came through. They cost me more than the cam, which I got via gumtree. Crow stainless which are half the price of yella terra.
Fitted ready for adjustment
2 new unis and all good, though i wish i could get rid of the steering shake between 100 and 120Mick wrote: ↑Sun Feb 20, 2022 4:35 pm and right on cue after being a big mouth i drove to Sydney AGAIN and in about the last 100ks it's developed a vibration at high speed and not all the time mostly above 100kmh and gets worse it's really bad up round 140-150, getting new rear screen and dual circuit brakes tomorrow so while it's on the hoist will be checking unis etc
Some insight in to why rockers failed maybe?
That will do it Clay they look like they have had a hard life mate
Yeah Neil 8 )
Battery got enough to start it so warmed up and set the rollies by ear + 1 turn. Some hassle getting the cover back on with the bigger hardware. The vacuum and fuel lines are close. I’m glad I spaced the thermostat housing out.
Snuk out under the radar down the back. Up to 60 on the Speedo a couple of times in second gear. 120kmh which I think is near enough 4900rpm. I’m impressed how smooth it is up there. First time I’ve really been able to appreciate the dough I threw at getting every thing balanced. Never had a sweeter reving six!
"First time I’ve really been able to appreciate the dough I threw at getting every thing balanced. Never had a sweeter reving six!"
Good to hear Clay- currently spending dollars doing same
Let's see if they can get it right this time...
Good luck with that
Well fourth time lucky it seems
Fuk this stupid phone
