Moderators: reidy , Blacky
Posts: 14271 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sun Jan 16, 2022 11:44 pm
You know the deal - change one thing , you have to change 3 others
Finished off the sway bar mounts , then sorted out the ones on the lower wishbones
Out with the old ……..
Post
by Blacky » Sun Jan 16, 2022 11:46 pm
… in with the new
Post
by Blacky » Sun Jan 16, 2022 11:47 pm
Then got stuck into the steering stops , had to be removed and relocated to suit the different calipers -
Post
by Blacky » Sun Jan 16, 2022 11:52 pm
Had to improvise with the lower ball joints to set the steering stops up - can’t fit the proper ones until the lower wishbones have been powder coated
Made up some new brake line supports and welded them on -
Post
by Blacky » Sun Jan 16, 2022 11:53 pm
mph
Posts: 787 Joined: Fri Oct 19, 2012 12:09 am
Post
by mph » Mon Jan 17, 2022 10:33 am
Wow really smashed out a lot of good jobs mate great work. Tyres normally let you know if you haven't any steering stops.
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Post
by Blacky » Tue Jan 18, 2022 12:39 am
Tonight was fiddle with the bonnet hinges night , they were close but not close enough, I had to take a few mm off the back of them so they don’t hit the firewall and I slotted the mounting holes to give a bit more adjustment. Also had to measure them up to buy the struts , need to be 275mm open and no longer than 205 closed , and 1000N pressure for those that are playing at home
Post
by Blacky » Tue Jan 18, 2022 12:41 am
Post
by Blacky » Tue Jan 18, 2022 12:44 am
gledge
Posts: 307 Joined: Thu May 28, 2015 11:01 pm
Post
by gledge » Tue Jan 18, 2022 12:47 am
I have been looking for struts for the last hour
gledge
Post
by gledge » Tue Jan 18, 2022 12:58 am
Wow I wish I had a bit of bonnet like that mate that would make life way easier....
Post
by Blacky » Tue Jan 18, 2022 1:11 am
gledge wrote: Tue Jan 18, 2022 12:47 am
I ordered a couple of pairs today , want me to order another?
gledge
Post
by gledge » Tue Jan 18, 2022 9:19 am
That would be great mate or just send me the info and I will just order the same ones.. which ever is easier
Posts: 2815 Joined: Fri Jan 24, 2014 11:12 am
Post
by FireKraka » Tue Jan 18, 2022 12:40 pm
Great work and mods there Blacky and that bit of bonnet looks like one I got back from the blasters
Post
by Blacky » Tue Jan 18, 2022 5:08 pm
Struts arrived today , 2 sets for me and a set for Gledge
