WALLY'S EK
Re: WALLY'S EK
There is only one way to settle this, gentlemen…..
Re: WALLY'S EK
😂😂😂😂 is that challenge by chance, I’d run Frank against you Wally you might be surprised 🤪🤪🤪
FJWALLY
Re: WALLY'S EK
Post by FJWALLY »
FireKraka wrote:ImageImageImageImage is that challenge by chance, I’d run Frank against you Wally you might be surprised ImageImageImage
Haha - I think someone else was doing the trash talk - I know my limitations Neil Image
gpi
Re: WALLY'S EK
Post by gpi »
My bad, misread hp for kw, even still, its going to get you to church a fair bit quicker on Sundays.
FJWALLY
Re: WALLY'S EK
Post by FJWALLY »
gpi wrote:My bad, misread hp for kw, even still, its going to get you to church a fair bit quicker on Sundays.
Ive got a 220kw FJ cruiser on 35’s that can do 4wheel smoke - maybe thats a better opponent
Re: WALLY'S EK
I'll mimic your words Wal, I know my limitations, :lol: :lol: :lol:
FJWALLY
Re: WALLY'S EK
Post by FJWALLY »
Putting some miles into her - having a little electrical issue with fuses blowing - wires are all good and no short but I’m thinking i might be getting a surge from either the alternator or maggie as its only when you give it some revs they pop - might need a resistor or relay in there - thoughts? Getting bolder with dropping the clutch - has no trouble going speedway on me round corners ImageImage
Re: WALLY'S EK
Good to hear you’re getting some miles up on it Rob. Dropping the clutch will end in tears with your stock drive line. Don’t ask me.
Re: WALLY'S EK
Errol62 wrote: Mon Jan 10, 2022 7:46 am Good to hear you’re getting some miles up on it Rob. Dropping the clutch will end in tears with your stock drive line. Don’t ask me.
Yeah - I became pretty proficient at changing out axles and gearboxes in Shake Rattle n Roll :twisted: :lol:
Re: WALLY'S EK
Neat pics Rob,
Are you blowing all fuses of just certain circuits? Are you running a standard loom with just the three (from memory) fuses?
FJWALLY
Re: WALLY'S EK
Post by FJWALLY »
In the Shed wrote:Neat pics Rob,
Just the two going stephen - two on door side - both 15 amp - loom is a new standard loom - we found a few exposed wires which must of been damaged in reassembly so replaced those but its still happening - can have car on and wiggle wires around with no issue so confident we dont have a short - the geni was replaced with a high output alternator type generator - possibly need some better earthing on motor to body maybe? All works fine with engine not under load
Re: WALLY'S EK
Interesting, be good to connect an amp meter in the circuit/s that fail and monitor as engine speed changes to see if there is a change in relationship to engine speed.
S
Re: WALLY'S EK
In the Shed wrote: Mon Jan 10, 2022 11:02 am Interesting, be good to connect an amp meter in the circuit/s that fail and monitor as engine speed changes to see if there is a change in relationship to engine speed.
S
Agree. One of the clamp on type ammeters would make it easy.
Wonder if the alternator reg is shagged, and he is getting 15+ volts at high spin speed?
Re: WALLY'S EK
Alt is putting its current to battery through harness rather than wire direct to battery?
FJWALLY
Re: WALLY'S EK
Post by FJWALLY »
Brett027 wrote:Alt is putting its current to battery through harness rather than wire direct to battery?
Yeah Alt to battery and Alt to body earth
