Wheel size
FbSTDwagon
Re: Wheel size
[/quote]
I doubt you will get a 14 x 8 under the bum , a 7 is about it. I have 14 x 6 on my ute - I think . I can measure them if you want ??
[/quote]
Blacky if it is not too much trouble that would be Awsome.
You haven’t got rolled guards?
I’m not rolling mine.
[/quote]
[/quote]
Drew
Re: Wheel size
In this photo, is where mine needs to sit, 17x8 with 225/50s, 1" lower scraping issues, not the arch but the inner guard, have about a pencil width to the body. Was meant to be pumped out a little while getting repainted, mother f@#$ didn't do it for some reason, would have gone for 235, only one size but hey, you can never have enough rubber.
You can go 7 or 8" 225 will fit both or 215 & will be able to sit lower. Won't go into off sets cause it has a shortened VN rear end.
Briby
Briby
- FB wheels.JPG (31.67 KiB) Viewed 1174 times
FB Restomod V8 Sedan
Re: Wheel size
Only way you can tell they have been rolled is by feeling. You can’t see it unless you lie next to the wheel and look up. If you won’t roll them then best stick with 6” all round or standard suspension height.
Re: Wheel size
You will get an 8” 17” wheel underneath but not an 8” 14” wheel , it’s not the rim that’s the problem it’s the The sidewall moving around that causes the rubbing
Re: Wheel size
I had 8x14" under the ute. They didn't rub (very much). 225/60 tyres and carefully chosen offset and they wont rub at all. Getting the offset exactly right is the hard part.Blacky wrote: Tue Dec 14, 2021 9:19 am You will get an 8” 17” wheel underneath but not an 8” 14” wheel , it’s not the rim that’s the problem it’s the The sidewall moving around that causes the rubbing
Re: Wheel size
yup ......
Re: Wheel size
yup, yup.
FbSTDwagon
Re: Wheel size
Ok so I thinks it’s that simple… hopefully… sounds like 6 inch is the go for what I want.Errol62 wrote: Tue Dec 14, 2021 7:33 am Only way you can tell they have been rolled is by feeling. You can’t see it unless you lie next to the wheel and look up. If you won’t roll them then best stick with 6” all round or standard suspension height.
Just need to work out the offset.
Drew
FbSTDwagon
Re: Wheel size
That blew my mind… like a moment in my late teen when I seen the light…Blacky wrote: Tue Dec 14, 2021 9:19 am You will get an 8” 17” wheel underneath but not an 8” 14” wheel , it’s not the rim that’s the problem it’s the The sidewall moving around that causes the rubbing
Drew
Re: Wheel size
Drew, use this chart and you shouldn’t go wrong. If I was doing it I would have the diff in so you know where the drum faces are then go from there.
https://www.google.com.au/search?q=whee ... oMXeilMwXM
Best to trial a wheel on the front then measure that to get the offset.
Re: Wheel size
Sorry mate i have been getting home late the last couple of nights, will get this measurement for you when I can.
FbSTDwagon
Re: Wheel size
Cheers Greg yes when I get the drums on I’ll do some measuring up and I’m sure I’ll work it out.
Blacky no dramas mate, only if you find the time to get it done.
Drew
Re: Wheel size
I’ll be swapping back to jelly beans soon so you’re welcome to try my 6x14” rims to verify your offset.
Re: Wheel size
Way too much negative offset on these but you could cut out the centres and fit your own. https://www.gumtree.com.au/s-ad/tanunda ... pasteboard Just need a pair of sixes for the front then.
Re: Wheel size
These 6” rims JUST clear with rolled guards
