So the fun was short lived.
To drill the holes for the wings to bolt to the firewall I have to fully fit the sub frame. Which means getting all 4 bolts in the legs of the sub frame, and the two tapered bolts that screw the mid point of the verticals to the firewall. All these points did not change in the resto, though a lot around the verticals did. No amount of hammering/grinding /bending or swearing would get the necessary clearance to get the inner drivers side bolt in. Just could not work out a way to get the whole frame to move in 5mm further.
So after 4 attempts and several hours doing my best Catherine Zeta Jones Entrapment impressions, took the sub frame off the stands, and tried to get the bolts in with the subframe lower at the front, then tilt it up into position.
Found a few more gotchas in this lowered state (remove/bend/grind/refit), but with a ratchet strap, hammer, and long punch, finally got it lined up.
- IMG_9276.JPG (602.76 KiB) Viewed 1209 times
And because I was so pleased with myself, I took a phot with the bolt in.
- IMG_9278.JPG (567.97 KiB) Viewed 1209 times
Well almost
- IMG_9279.JPG (590.33 KiB) Viewed 1209 times
The bolt is sitting low and for now that is the best I can do.
My solution for locating and fitting the outer bolts was pretty simple
- IMG_9273.JPG (534.5 KiB) Viewed 1209 times
But can't do that with the inner.
And as I stared at it for long enough, was the hole in the centre of the mount used during manufacture? Can't think of another reason, except to let water and dirt in.
- IMG_9274.JPG (566.27 KiB) Viewed 1209 times
