Moderators: reidy , Blacky
Posts: 14089 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Fri Nov 26, 2021 7:15 pm
Been meaning to knock one of these up for a few years now, I had a pair of seat sides that were rusty on the vertical part and being a pack rat I couldn’t bring myself to throw them out so I thought they would make a good console
First up I cut the top bit off -
Then cut it to length and lopped the front bits off and tacked it together
Post
by Blacky » Fri Nov 26, 2021 7:18 pm
Then I knifed this bit off , put the left on the right and the right on the left to form the back up
Post
by Blacky » Fri Nov 26, 2021 7:20 pm
And glued it all together, going to whack a couple of cup holders and a USB port for charging phones on top , still have to patch the adjuster hole up and make some tabs to screw it to the floor , took it to work and blasted it so now it’s ready for a final grind up , bog and paint. If it doesn’t get forgotten about it will be ready for Nuriootpa
Posts: 11524 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Nov 26, 2021 7:40 pm
Cool idea blacky
Post
by Blacky » Fri Nov 26, 2021 11:54 pm
Errol62 wrote: Fri Nov 26, 2021 7:40 pm
Cool idea blacky
waste not , want not my good man
funkyscooter
Posts: 706 Joined: Wed Aug 16, 2017 8:12 am
Post
by funkyscooter » Sat Nov 27, 2021 7:23 am
You're the man Blacky!
Well done - a great stylistic fit to what you would expect a factory console to be at the time.
I am spending a lot of thought time on my console. I want something modern (apple car play), but packaged up in a period correct style housing. Great inspiration.
My original idea was to repurpose the hump in the dash where the speedo sits, to use as the sides. The thought of finding and cutting up 2 put me off.
Finding so seat sides might be a little more realistic.
Scott
Posts: 5709 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Sat Nov 27, 2021 8:34 am
Love the use of the curved panels - ties in really well.
Just needs one of these put into the forward end, on a bit of an angle
https://www.ebay.com.au/itm/13270939854 ... gINafD_BwE
Post
by Errol62 » Sat Nov 27, 2021 9:26 am
EK Monaro prototype 8 ) 8 )
Post
by Blacky » Sat Nov 27, 2021 10:40 am
I already have one on the dash Harv, another would be just plain greedy
Belly760
Posts: 205 Joined: Wed May 26, 2021 9:14 pm
Post
by Belly760 » Sat Nov 27, 2021 1:13 pm
Wow Blacky. That looks awesome.
FB Ute Stock
EK Ute in Pieces
Post
by Errol62 » Sat Nov 27, 2021 2:10 pm
On the ute blacky? You might have about 6000rpm up your sleeve!
Post
by Harv » Sun Nov 28, 2021 6:53 am
I have similar plans...
Jones tacho.jpg (644.6 KiB) Viewed 9236 times
Post
by Blacky » Sun Nov 28, 2021 9:41 am
Thats cool Harv - did you have a chat with Doc about the gear you bought ? It was feeding a Hilborn hat which is why it had 4 nozzles
Post
by Harv » Mon Nov 29, 2021 7:07 am
Crap... I have the attention span of a goldfish. Forgot to call him. Will try and give him a yell this week.
Post
by Blacky » Tue Jan 11, 2022 11:58 pm
Did the bog work and got it into primer today
