Console
Console
Been meaning to knock one of these up for a few years now, I had a pair of seat sides that were rusty on the vertical part and being a pack rat I couldn’t bring myself to throw them out so I thought they would make a good console
First up I cut the top bit off -
Then cut it to length and lopped the front bits off and tacked it together
Re: Console
Then I knifed this bit off , put the left on the right and the right on the left to form the back up
Re: Console
And glued it all together, going to whack a couple of cup holders and a USB port for charging phones on top , still have to patch the adjuster hole up and make some tabs to screw it to the floor , took it to work and blasted it so now it’s ready for a final grind up , bog and paint. If it doesn’t get forgotten about it will be ready for Nuriootpa ImageImage
Re: Console
Cool idea blacky
Re: Console
Errol62 wrote: Fri Nov 26, 2021 7:40 pm Cool idea blacky Image
waste not , want not my good man :thumbsup:
funkyscooter
Re: Console
Post by funkyscooter »
You're the man Blacky!
Well done - a great stylistic fit to what you would expect a factory console to be at the time.
I am spending a lot of thought time on my console. I want something modern (apple car play), but packaged up in a period correct style housing. Great inspiration.
My original idea was to repurpose the hump in the dash where the speedo sits, to use as the sides. The thought of finding and cutting up 2 put me off.
Finding so seat sides might be a little more realistic.
Scott
Re: Console
Love the use of the curved panels - ties in really well.
Just needs one of these put into the forward end, on a bit of an angle :)...
https://www.ebay.com.au/itm/13270939854 ... gINafD_BwE
Re: Console
EK Monaro prototype 8 ) 8 )
Re: Console
I already have one on the dash Harv, another would be just plain greedy Image
Belly760
Re: Console
Post by Belly760 »
Wow Blacky. That looks awesome.
FB Ute Stock
EK Ute in Pieces
Re: Console
On the ute blacky? You might have about 6000rpm up your sleeve!
Re: Console
I have similar plans... :mrgreen:
Jones tacho.jpg (644.6 KiB) Viewed 9346 times
Re: Console
Thats cool Harv - did you have a chat with Doc about the gear you bought ? It was feeding a Hilborn hat which is why it had 4 nozzles
Re: Console
Crap... I have the attention span of a goldfish. Forgot to call him. Will try and give him a yell this week.
Re: Console
Did the bog work and got it into primer today
