Ol' Rusty - FB/EK Sedan
Re: Ol' Rusty - FB/EK Sedan
I got lazy, and took option d./ for the wagon:
d./ recognise you can't weld. Cut the ends off with an angle grinder and leave the swage ends missing. Paint it black so no-one notices :lol: :oops:
Ditto
Option “E” for me -
You CAN weld, but you can’t be bothered ImageImage
Wrong pic ……
Yeah Blacky, it's time that you got out there and made a mess. Show us how it's done🤗.
I took option E
Cut the width, then welded in some folded c channel.
The radiator frame slides into it, very strong and a self tapper holds it in.
It cant move side to side or up and down because of the top support, looks good to !!
funkyscooter
Post by funkyscooter »
Think I'm done with this. Needs paint, but I've gone over it with deoxidine and sealed it for now with easyphos so should be good for at least 6 months stored dry. Just got to find somewhere to hang it up. Look forward to having a bit more room to move.
Front had a few holes to fill, but apart from that it was just a bit (lot) of time on the wire wheel, powerfile, and die grinder.
Inside just needed a tidy up where I opened up the front for the radiator. Bit of surface rust where the sides join the front, ground out as best as I could, wire wheel, then poured some Ranex in there to reveal what I had polished up and not removed. More grinding, wire wheel. Done.
Now back to the firewall........
Scott
Very nice indeed
Hi Scott, I've got some bits that could do with a clean up like that. When's a good time to drop them 'round?😁 Wow!!!
funkyscooter
I reckon you should just spray some clear on that. Love the rusty patina! Shiny is overrated.
Scott
funkyscooter
The best I could do hanging it up. Clears my head. Just. Image
Scott
Scott
funkyscooter
Might have to find a new home for the sub frame, hit my head for the third time today. AirPod fell on the ground too and picked up a bunch of metal. Good clean up before I shove that back in my ear. Pretty average day really. Not much work got done. Lots of thinking. Image
Scott
Scott
We all have days like that unfortunately - might need the compressor fired up to clean that earbud !!
funkyscooter
Yeah Blacky, compressor then lens cleaning fluid and a soft rag followed by a check under the desktop magnifier.
Using a die grinder leave sharp little splinters of metal everywhere, and most end up in my fingers. Have a sewing needle and tweezers hung up in the shed to extract the little bastards.
Would not want one of those in my ear :evil:
Scott
Yeah those die grinder shards are like tiny needles, and they seem to find their way into all sorts of places you would rather they didn't :shock: :shock:
