Hi ,
Isolating in the garage for the next couple of weeks so may finally make some progress..
Looking for advice on stainless trim attachment . I have clips from rare s , but they don't seem to be a good fit. Quite possible it is operator error .
Do you just give it a whack ?
And what is the end clip... larger hole //?
Advice appreciated
Thanks ,
Steveo
Trim clips and end bits
- EK Trim .jpg (1.01 MiB) Viewed 772 times
- funkyscooter
Re: Trim clips and end bits
I got these after guessing from what was left on the car - don't know what was holding the trim on.
Look a bit large as its closer to the camera. Not sure if they will work, and a long way off finding out
Scott
Thanks , I have some of those and my best guess at fitting is as picture ..
. it doesn't seem very robust..
- end clip .jpg (1.23 MiB) Viewed 752 times
The ones on your car look about right to me Stevo, but I’m no expert on Specials. I was going to get the ones Scott posted to fit the commercial/standard guard spears as I reckon they matched the originals on mine. Ended up re using original ones in the end.
That looks about right
Thanks .. all good
- EK trim.jpg (687.89 KiB) Viewed 694 times
Second that. Looks very straight.
