Clay's Fabulous Big Exciting Kooky adventure
Re: Clay's Fabulous Big Exciting Kooky adventure
If you have to be inside, that seems a perfect spot to be Clay.
- funkyscooter
Ha! Looks horrible!
Scott
So set out for home this morning via Goulburn. Car going well. Then it jumped out of top. 15 minutes later did it again, only this Time engine started misfiring and popping from the carb. I feared a head gasket but no obvious oil water at this stage. Will run and no bad vibrations but popping and missing and tappet noise toward the rear. Distributor and leads look fine.
Leaning toward a tappet or cam failure. NRMA called.
Number four pot appears to be the issue. Backfiring stops when I remove the lead. Any way Belly to the rescue with car trailer.
Never mind NRMA. Make sure your forum subscription is up to date before leaving home!
Weird shit you find on the side of the road
Stay in the ute Clay. Stay in the ute
The adventure continues...................
Clay,
I'm thinking maybe a sticking valve.
Cut the filter open Clay....
Thanks guys. Will do.
Broken tappets. Should have brought spares.
Nope. Running pretty good now. Just need an occy strap to hold her in top.
FB ute shed session.
