Gimme 5 years
Re: Gimme 5 years
When you say end play what do you mean ?
I know most gearbox rear shafts move around and are supported by the tail shaft yolk bearing, I'm not familiar with the crash box but I assume the bush can be replaced in the extension housing ?
Also I had a grumble once and it turned out the uni was stuffed, I was pretty sure it was the gearbox.
Radiator is nice .
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Hi Greg - yeah a bit of up and down that can get taken up by the bush in the extension but the end play I'm referring to is in and out of the box. Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
got a spare gearbox - just not sure which one it will be yet
gearbox 7.jpg (96.57 KiB) Viewed 1092 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
found another noisy bit from the ute gearbox (gbox a) - counter gear shaft is a bit rough
gbox a 3.jpg (58.05 KiB) Viewed 1065 times
still have to pull apart the other gearbox (gbox b) - but I can already see why it was decommissioned
gbox b 1.jpg (45.84 KiB) Viewed 1065 times
Patrick
Re: Gimme 5 years
If the rear main bearing's outer race has spun in the gearbox case, it may be "challenging" to find the ends of the bearing retaining clip, because it will have spun along with the outer race.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
ardiesse wrote: Sat Mar 20, 2021 2:50 pm If the rear main bearing's outer race has spun in the gearbox case, it may be "challenging" to find the ends of the bearing retaining clip, because it will have spun along with the outer race.
Hi Rob - yeah, luckily just the rear cage of the double bearing gave way ... but as I disassembled the gearbox and pushed the shaft forward the other lot fell out so I had the outer race tight in the box and the inner race tight on the main shaft.
taking the outer race out went as per normal (with the original style snap ring with the tag on it)
... for the inner race I had to hold the gears in place with rags and wooden wedges so I could tap the shaft through
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I emptied out gbox b today - there's enough good bits between the two of them to put one together without buying a kit (that's how it would have gone with my first couple of cars forty something years ago) - but I've ordered the double row bearing kit for this one
it took a fair bit of flushing to get rid of all the glitter - and then I went through with a magnet - took half a dozen passes until it came out clean
the front race of the bearing was still holding the shaft in place and the glitter appears to have been contained in the speedo drive area (though I'm sure it travelled a bit with the oil) - speedo drive lost a tooth - everything else checks out good ... I'd say it wasn't driven after it squealed
gbox b 2.jpg (117.32 KiB) Viewed 1030 times
gbox b 3.jpg (118.4 KiB) Viewed 1030 times
gearbox 8.jpg (112.68 KiB) Viewed 1030 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
got something for the shelf out of it too
gearbox 10.jpg (79.46 KiB) Viewed 1012 times
Re: Gimme 5 years
Very artistic Patrick.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
some rough tools
I thought that while I'm waiting for the gearbox kit to turn up, I may as well get some bits ready. I started by pressing the bearing off the clutch gear (it wasn't coming off with light tapping). I'll probably be using the press and a bit of pipe to press the new one on as well.
t clutch gear bearing.jpg (28.72 KiB) Viewed 991 times
that got me thinking about the main shaft rear bearing - which I'd prefer to press in rather than tap in (I didn't mind tapping the old one out because it was going in the bin anyway) - so I got a couple of bits together ready for that
t rear bearing 1.jpg (31.75 KiB) Viewed 991 times
when I was pulling the bearings out of the cases, I changed the profile of my snap ring wedge a few times from the one I'd seen pictures of, until I was reasonably happy with it (by pushing the tool in from underneath I could see where it was making contact - I also chamfered the edges)
t rear bearing 2.jpg (36.65 KiB) Viewed 991 times
a few more bits to pull the main shaft through
t main shaft.jpg (29.96 KiB) Viewed 991 times
and some bits of 16mm chrome curtain rod (painted ones leave paint behind) to load the counter gear rollers and hold the rear thrust washer ... my plan is to leave the rod in place and push it through with the new counter gear shaft
t counter gear.jpg (33.69 KiB) Viewed 991 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I should have finished the outside jobs before this rain set in. I wanted to put in an order so went out to remove the clutch and check it out - at least you don't get rained on once you are under the ute
supposedly you can let them go to 0.3mm (12 thou) off the rivets but at 0.64mm I can't see the point in putting this back in and have ordered a new kit ... I'll stick with 200mm
clutch 1.jpg (64.97 KiB) Viewed 965 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Errol62 wrote: Sat Mar 20, 2021 10:13 pm Very artistic Patrick.
thanks Clay - I call this one 'magnets on a garage door'
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
the gearbox rebuild kit turned up today, just before bourbon o'clock, so I only had time to press the rear bearing in
gearbox 11.jpg (81.7 KiB) Viewed 908 times
gearbox 12.jpg (26.09 KiB) Viewed 908 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I decided to pull the mainshaft through the rear bearing today
gearbox 13.jpg (68.25 KiB) Viewed 887 times
It was all going well so I kept going until all the gears were in
Patrick
Re: Gimme 5 years
Nice work p
