![Image](http://uploads.tapatalk-cdn.com/20210304/cfa77378ebd0d5df9035a2ebe2537187.jpg)
I wondered what the go was there when I changed my springs - luckily found a good set of sedan brackets and rubbers from rares were sedan also - niceErrol62 wrote:Have to decide whether to use commercial or sedan axle mount rubbers. Not sure why they were different. Sedan left, ute right.
Could it be a flex issue - ie the thicker spring pack of the commercials behaved differently with the thicker rubber?Errol62 wrote:Just as you say Rob. But why should they complicate things. More durable?
Harv wrote: Sat Mar 06, 2021 6:33 am Interesting.
Up to FC, the commercials had the same insulator as the sedans/wagons. From FB onwards, sedans/wagons and commercials had separate insulators (7412388 and 7414876) and retainers (7412389 and 7414877). No difference in the mounting plate or hardware, other than different length u-bolts to deal with the different spring packs.
Sedans got the 7414283 spring pack (four springs, numbers 1-4), wagons got the 7412386 spring pack (five springs, numbers 1,2,3, 5 and 6) whilst commercials got the 7419193 spring pack (five springs, numbers 1-5). The springs themselves (numbers 1 through 6) are shared between all three models, so unlikely that the insulator was different just to suit a special commercial spring. Guess it is probably just a heavier-duty rubber/plate.
