Gimme 5 years
FJWALLY
Re: Gimme 5 years
Post by FJWALLY »
Did you have the cylinders stainless sleeved?
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
FJWALLY wrote: Wed Jan 20, 2021 7:31 am Did you have the cylinders stainless sleeved?
nah, bought new wheel cylinders, master cylinder and hoses
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Harv wrote: Tue Jan 19, 2021 3:07 pm A word of caution on those rubber blanking plugs. I fitted some to the FB, and all looked good. At some stage though they caught on the adjuster cap, and canted it. The cap canted the shoe, and all hell broke loose. Squealing, and worn lining. I had a good discussion with Burt Bros about it, and they reckon the aftermarket plugs are deeper than the originals. I can't be sure - I've never seen an original. Worth a good check though once they are in.
Thanks Harv :thumbsup: :thumbsup: :thumbsup: ...
here's how the plugs look with the drum off
plug 1.jpg (61.85 KiB) Viewed 753 times
the backing is 5mm so I halved it
plug 2.jpg (53.66 KiB) Viewed 753 times
plug 3.jpg (56.52 KiB) Viewed 753 times
Patrick
Re: Gimme 5 years
That's the way paddy. Originally they would've been metal clips which are no doubt shallower. I've got the clips on my front brakes. Nothing on rears but I will have to get on to that.
Re: Gimme 5 years
Good outcome 😀
FJWALLY
Re: Gimme 5 years
Post by FJWALLY »
Good Solution and thanks for the heads up Harv - better to fix before it's F...d.
62ekute wrote: Wed Jan 20, 2021 2:00 pm
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
passenger side front brake shoes are near new (although the trailing shoe lining is debonding)
driver's side nothing
Front Brakes 1.jpg (96.26 KiB) Viewed 722 times
I'll get the originals re-lined; but, I've got these ready to go in anyway
Front Brakes 2.jpg (110.59 KiB) Viewed 722 times
Patrick
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
got ACT Brakes to put these on the lathe for a bit
Patrick
FJWALLY
Re: Gimme 5 years
Post by FJWALLY »
Cool - mine were new cylinders when I bought it 4 years ago and within that 4 years were so corroded they needed sleeving - the response from the sleeved cylinders is heaps better than non-sleeved also - much better fit tolerances
62ekute wrote: Wed Jan 20, 2021 8:06 am
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
the heat and then the rain has kept me away from the EK for a bit ... today I thought I'd start it up and have a bit more of a listen.
I noticed a flat spot if I blip the accelerator so had a bit of a look ... the accelerator pump was just dribbling instead of squirting. I took the top off the carby and could see a water bubble in the rectangular hole above where petrol is supposed to squirt out. I tried different ways to blow, suck and pump it through but in the end poured some metho in to get rid of it
hopefully it's just a one off - I thought I better check if I got some in the tank so I made up a remote starter and pumped some petrol into a jar - all good.
remote starter.jpg (77.89 KiB) Viewed 634 times
also decided to put a fuel filter in
fuel filter.jpg (85.06 KiB) Viewed 634 times
considering I'd been squirting carby cleaner in and using metho, I decided to go back to a leather plunger seal - I had a good one in a spare carby...though I assume they make the new ones out of something durable anyway
I don't have tool 6A20 but I do have poly pipe
accelerator pump 1.jpg (91.38 KiB) Viewed 634 times
accelerator pump 2.jpg (56.96 KiB) Viewed 634 times
Patrick
Re: Gimme 5 years
Good ol single strommie. Hopefully that’s sorted. Don’t be surprised if flat spot persists until she warms up nicely.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
The weather is a bit better today so I made a start on the front end
got out the book - it said to get a feeler gauge and measure this gap - max 4 thou
only 76 thou over
king pin 1.jpg (55.46 KiB) Viewed 598 times
I've got these to go in
king pin 2.jpg (114.79 KiB) Viewed 598 times
Patrick
Re: Gimme 5 years
Hmmm.... close but nah, thrust bearing probably collapsed.
Re: Gimme 5 years
Hi Patrick, I tried those Rares reco units too and found that the inner and outer wheel bearing mounts had been machined too much by Rares and the bearings were not a snug fit. There's ways around it, but in my case I decided to put kits through my old ones instead. If you go down that track, reamer is here if you want to borrow it. Brett
Re: Gimme 5 years
The king pin retaining cotter pin is missing on all three (yours with the excess clearance, and the two reconditioned ones).
