Errol62 wrote: Mon Dec 21, 2020 11:44 pm
God I thought you had cut up the wagon for a sec there.
I reused the headlining in my sedan with considerable success. Used a donor lining to patch up a few torn bits, mainly C pillar bottoms where the rear seat back had come in and out too many times. Main issue I found is that the material that the wire bows go through tends to rot.
Yeah mate the material that hold the bows is pretty soft but I’ll really have a good look at it when the time gets closer.
Errol62 wrote:White spirits on a rag from recollection but trimmer suggested soap and water with a nail brush. Lay on a bench top and scrub vigorously.
I found “shift it” worked really well - spray on and a soft brush then wipe off well with wet rag
Kenco Shift It (from Autobarn) is awesome on old trim. It's an old Steve Jackson trick that works really well. Soap-and-water the trim, rinse, then work in the Shift It with a nailbrush. Rinse and repeat. Dry off, then add Armourall/Meguiars etc to protect it.
Cut my teeth on the first rust repair today.
The rust hole was the size of a 5c piece but the surrounding metal was so thin I had to replace a larger section just to get decent metal to weld onto.
In the Shed wrote: Wed Dec 30, 2020 10:31 pm
Nice work Drew,
The dipping of the Y frame came up good. You heading down for the All Holden Day at Glenelg in a couple weeks?
Gday Stephen, yes I most definitely will be there!
Should be a good day out!
