Moderators: reidy , Blacky
Posts: 2264 Joined: Wed May 16, 2012 10:18 pm
Post
by In the Shed » Wed Nov 11, 2020 10:19 pm
funkyscooter wrote: Wed Nov 11, 2020 9:26 am
Scooter,
I see you have the supervising engineer monitoring your progress. Always handy to have an extra pair of hands available.
Post
by In the Shed » Wed Nov 11, 2020 10:21 pm
In the Shed wrote: Wed Nov 11, 2020 10:19 pm
Scooter,
funkyscooter
Posts: 708 Joined: Wed Aug 16, 2017 8:12 am
Post
by funkyscooter » Thu Nov 12, 2020 7:36 am
Yeah, he's been a great help - he pretty much single handedly degreased underneath the car.
Scott
Scott
Posts: 14211 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Thu Nov 12, 2020 10:18 am
Good on him
start 'em young , my young bloke had no interest at all when he was that age, even bought him a project 1 tonner that he wanted and told him I would pay for the build and it would be his provided he helped build it , ended up I built it and sold it
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 4:58 pm
Some of the cleaning efforts
Working back to front. Lot of elbow grease to clean off that grease. And a few cans of SCA degreaser
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:00 pm
Wheel arches are a pain and this is where the platform of the hoist is not your friend
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:01 pm
Looking from the engine bay to the back
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:07 pm
Diff out
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:09 pm
K-mac sway bar out. Removing the plastic dip coating, new bushes and a coat of black.
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:21 pm
Axles out. Those bearings look a bit rough but weren’t noisy.
. Is the orientation the right way round with the I ring on the inside? Note to self, take them out when the diff is still bolted to the car!
Scott
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 5:27 pm
So now I need to get the pinion nut undone. Marked the nut position to reinstall to the same tension. Pretty sure I broke a bit off my breaker bar undoing this.
After I went to all this effort I read that you can jam a rag in the diff to stop the pinion turning. Guess which method I used to do it back up?
Scott
Posts: 1203 Joined: Thu Jan 19, 2017 9:57 am
Post
by ardiesse » Thu Nov 12, 2020 8:17 pm
Rear wheel bearings - yes, they've been installed backwards. O-ring on the outside is the normal way. But don't change them just for the sake of correct installation.
When you take the pinion flange off, you'll probably be surprised by the amount of wear where the lip of the seal bears on the flange. You might have to chase up a less-worn pinion flange, and that's about where it becomes a job for a diff specialist.
funkyscooter
Post
by funkyscooter » Thu Nov 12, 2020 8:38 pm
Thanks for the tip Rob. Didn’t get a picture with the flange out. But don’t think it was worn and the new seal was a snug fit.
Figured the bearings were the wrong way round. Read that the o ring is to seal water and dirt out, not oil in. Is that true? Anyway decided to leave well enough alone for now.
Scott
Posts: 11599 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Thu Nov 12, 2020 9:40 pm
Looks nice and clean now . Well done men!
Post
by In the Shed » Thu Nov 12, 2020 10:33 pm
The young fella has done a great job cleaning off the gunk.
