Some workshop manual info:
FX: 15x3.50D or 15x4.00J
FJ: 15x4.00J
FE-HR: 13x4.50J
HK: 14x5.00J
HT: 14x5.00JJ 1.19” offset or 14 x 6.0JJ 1.06” offset
HQ: 14x5.00JJ or 14 x 6.0JK on GTS Coupe
WB: 6.00” JJx14 steel, 7.0JJx15 alloys (Statesman Caprice), 6.00” JJx14 heavy duty (1-tonner), 6.00” JJx14 alloys (van + ute), 6.00” JJx14 wire spokes (Statesman Deville)
LC/LJ Torana: 12x4.00J (4 cylinder), 13x4.50JJ (6 cylinder), 13x5.50JJ (GTR)
HB Torana: 3.50 B x 12 L (4.00” PCD) or 4.00Jx12 (1969)
LH torana: 4.50JJx13 1.33” offset (S&SL), 5.50JJx13 1.13” offset (SLR)
VB/VC/VH Commodore: 15x6.00JJ, 44mm offset
VC Commodore 4-cyl 13x5.5JJ
VL 6.00JJx14
The “J” or “JJ” part refers to the rim bead profile (not the tyre speed rating). There are a lot of different profiles (J, JJ, K, JK, B, P, D etc).
- bead profile.jpg (30.86 KiB) Viewed 6951 times
Interesting too that early Holden stud pattern is not 4.25" PCD... it's 4.24".
