Gimme 5 years
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
FJWALLY wrote: Mon May 04, 2020 8:17 pm what are the screws holding or are they just filling holes?
62ekute wrote: Mon May 04, 2020 7:19 pm so...what's usually on the parcel shelf worth drilling out? paint label?
just a piece of stiff material to block off the hole
Re: Gimme 5 years
Nice work on the guards mate can you come and do a couple for me :lol: :lol:
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
FireKraka wrote: Tue May 05, 2020 9:53 am Nice work on the guards mate can you come and do a couple for me :lol: :lol:
thanks Neil...maybe I can cross the border on compassionate grounds - are the guards really bad? :laughinggg:
Re: Gimme 5 years
I've got 6 mate mate, out of the 6 I only have 2 for one side (can't remember which side :roll:) a couple of them are not great and one is painted so don't know whats under it yet, will know more when I get them blasted.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I spent the day tinkering on the Sprinter so nothing new on the EK - but I took a couple more photos of the guards
As usual, I didn't take enough 'before' and 'during' photos ... so I zoomed in on one of the original car photos and I took some more 'afters' - (though they'll probably become 'durings' if I revisit the guards later)
guard a.jpg (129.86 KiB) Viewed 775 times
guard b.jpg (67.21 KiB) Viewed 775 times
guard c.jpg (78.31 KiB) Viewed 775 times
guard d.jpg (107.02 KiB) Viewed 775 times
Re: Gimme 5 years
Looks like a great job you’ve done on those guards Patrick. I’m still trying to get mine looking straight after rust repairs, with the crease line along the top being particularly challenging, back toward the window.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Clay ... I reckon that when the light hits my guards in different directions I'll find things that could be better..I think of this as being the 'solid and protected from the weather' phase.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
I spent a few hours under the car (mainly the drivers side where welding is completed) and in the sub-floor area with a wire brush and bitumen paint
...there's some wasted space down there...has anyone put in an access hatch?
sub floor a.jpg (92.01 KiB) Viewed 737 times
subfloor b.jpg (72.08 KiB) Viewed 737 times
FJWALLY
Re: Gimme 5 years
Post by FJWALLY »
I put my battery behind passenger under there - need to be able to remove the boards to replace but can charge from under hood no issue
Re: Gimme 5 years
Thought about it. Moving the battery is a good idea. They are pretty we’ll maintained each free these days, and it improves the handling of the car and battery life. I probably won’t put in a hatch, just make the entire panel easily removable using dzus fastners or similar.
FJWALLY
Re: Gimme 5 years
Post by FJWALLY »
Errol62 wrote:Thought about it. Moving the battery is a good idea. They are pretty we’ll maintained each free these days, and it improves the handling of the car and battery life. I probably won’t put in a hatch, just make the entire panel easily removable using dzus fastners or similar.
Yeah mine is same - only need get to it if its stuffed
Re: Gimme 5 years
[/quote]
Hey Patrick,
You doing some good work to that ute mate, keep chipping away. I put an access hatch in my floor behind the passenger side. It has a lock and a door switch that operates LED lighting too. See this link http://www.fbekholden.com/forum/viewtop ... 8&start=15
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Stephen, yeah, chipping away is how I see it - I always like this stage of a project because there's a lot of different things to do - so I can chop and change depending on what I feel like. Patrick
Re: Gimme 5 years
Hi Patrick I did similar to what the other guys have said put battery behind passenger side but I made my panel go right across so I can remove if needed also able to store some tools and maybe jack on drivers side, I think you can see the panel in the pic below.
First pic was when I was making it and second is fitted.
Re: Gimme 5 years
mine has a lift up full width front half similar to Neils but longer, back to the front of the wheel arch . I carry cleaning gear, a toolbag and some spare parts in there , and on the way home from the nationals it is also usually full of wine :ebiggrin: :ebiggrin: :ebiggrin:
