Hi,
Steve – stock is good and I do appreciate a rebuild but subtle custom is for me.
The change to a rear FC sedan bumper, which has been done before a number of times, but I do not like the over ridders.
Clay scored the bumperettes for his ute.
I looked at Neil’s rear bumper on Frank but not sure on the painted finish.
There are spray on chrome like Hydrochrome and Exteme Hyrochrome out of the UK but for $600 + shipping maybe a little expensive just to try.
https://www.youtube.com/watch?v=A6kypid0XG0
Purchased this one from Cary, one of our club members and straightened it.
- FC Bumper 1.JPG (115.46 KiB) Viewed 1395 times
- FC Bumper 2.JPG (102.12 KiB) Viewed 1395 times
I did consider a single piece bumper but the re-chrome cost sky rocketed to a quote of $1,300 +
Straighten and narrowed it, to tuck the ends in closer to the body and then chromed.
I lowered the number plate surround, to remove the gap between the top of the bumper and the bottom on the surround. Normally you would see the body but as I intend to use the narrow number plates I wanted to clean this up.
- rear bumper.JPG (106.22 KiB) Viewed 1395 times
I will still use the domed bolts to attach the bumper and Anne-Marie like’s bling and the chrome bumpers hits to spot.
The front bumper has been narrowed and off the A Class Plating this week.
- Front bumper.JPG (149.26 KiB) Viewed 1395 times
Did not like the joining faces on the rear bumper so made a couple of gaskets.
Needed to slice the rubber from one section into a ¾ curve and glue to the flat section.
Needs a little tweaking but happy so far.
- Gasket 1.JPG (119.91 KiB) Viewed 1395 times
- gasket 4.JPG (88.07 KiB) Viewed 1395 times
- gasket 3 (2).JPG (194.87 KiB) Viewed 1395 times
Lots more time spent that I anticipate to modify the bumpers. A lot of weld, grind, re-weld, file and hand sanding.
But as we know with chrome you only get a good result if the substrate is smooth.
