Clay’s Wedgewood Blue FB Ute
- Wrongway Roger
As they say " nothing to see here, just move along ", ha ha.
Showed Clay the tail lights yesterday that I will be using but swore him to secrecy.
I may start a new thread on my build, if I have time.
18.4C 63%
Already a small run on the b pillar. I'm allowing 20 minutes between coats.
Rogers new stick.
Two coats in, 20C and 61%. Acryilic primer 1:1, 1.5 turns out, 23psi full fan.
needs a few repairs like mine
The repairs are the price of the over riders.
Warmer tomorrow. Will h a be a go at painting the tank with this.
Hey clay did you know that Adz now has a heated booth up the road??
Thanks Glen that could be very handy.
18C 55%. Paraglaze 2k urethane G113 metallic one shot. 2:1 plus 10%. 25psi, 1.5 out, full fan. Getting toward 2pm and supposed to get to 23C. Warming the paint up.
Hmmm, tricky stuff. Ran like de'Castella. I only have a 2.0mm gun.
Anyway decided I like the colour for honeypot, column and head lining trims. I mixed half what I had so using it up. Will rectify the tank and go again another day.
I did the top side second and was careful so no runs. Next time I can just paint the bottom on the flat. Just holding the gun further away and less overlap. It's a bit different go acrylic primer.
Bonnet hinges and striker would look good in this. Pity I already painted them in SCA epoxy enamel. It was over a year ago. Might give it a try on top.
The door strikers and hinges come up really good just being zinced - relatively cheap and not as susceptible to chips and rust - I just got a heap together like bonnet hinges - striker and any external mechs and did a basket - was about 350 a basket I think - just a thought
Using it up
Hi Clay the silver looks good mate as you know I like the silver on colour contrast.
Are you going to take advantage of the heated spray booth somehow I don't think you want to wait another 6 months to get colour on your ute.
