Red Rattler Revamp
Re: Red Rattler Revamp
You are onto it MPH - I will have a look tonight and see if I have just painted up the wrong one - That's the problem with having so much shite lying around, could be as simple as this !!! :thumbsup: :thumbsup:
rosco
Post by rosco »
If my memory serves me correctly, the red motor engine mounts differ left to right.... don't ask me which one is the smaller - but they are different.
On one side, the plate sits in front of the rubber mount centre... and the other side, it sits behind.... I know I had issues with these and that was why my engine wouldn't line up when we first fitted it... it was angled off to one side.
Finally got the engine mounts sorted - by building new ones Image after MPH pointed out the 2 different mounts I went looking and found 3 different mounts in my stash - and none of them were right so I made another.
Motor set up where I need it to be Image
Mounts made painted and installed and started to get some bits fitted.
Also got the quarter panel glued on ImageImage
Now it has a gap between the bootlid and the quarter - the bootlid used to overlap it Image
Pic didn’t load
The pulley drive and bracket set up looks very tidy blacky.
Pretty extreme way to re-gap the boot lid. Are you going to do the other side, you know, just for the hell of it? Snicker, snicker.
mph
Post by mph »
Ah man i could look at that engine bay for hours well impressive work mate.
So 3 mounts was one sticking out longer again or different shapes all together
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
mph
Post by mph »
Blacky wrote:Threw it all together and it spins as free as a bird - only drama is a 5mm gap between the wheel and the indicator section, so I stripped it down, marked it up and went to machine a new circlip groove in the bastard and the lathe decided that it was time for a rest ImageImage
So I fitted the bonnet hinges instead ImageImageImageImage
Hey mate the bracket part of the hinge that bolts to the bonnet did you weld to the original ve one or make a full new one and press in new bolt / rivets ?
FB-Special
Big block 161 :lol:
Holley sniper EFI.
It’s been that long I can’t remember :oops:
There is a plate welded to the existing part of the hinge mate.
mph
Post by mph »
Blacky wrote:It’s been that long I can’t remember :oops:
Too many beers in Qld and not enough in your shed building the rattler, its doesnt appear in the pic to have weld marks on it and a nice curvature like its pressed from one piece?
(Im just wanting to sort hinges and a booster with front and rear separate brake lines when my hr front goes in).
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Looking at that pic Clint, it is welded to the original bracket, they dont sit QUITE far anough back , and the front bolthole to gas strut mount is the limiting factor. Thinking while looking at it now it may be best to move the mounting pin for the strut forward, will probably create new dramas though, maybe they can go inboard ............ food for thought.
mph
Post by mph »
Blacky wrote:Looking at that pic Clint, it is welded to the original bracket, they dont sit QUITE far anough back , and the front bolthole to gas strut mount is the limiting factor. Thinking while looking at it now it may be best to move the mounting pin for the strut forward, will probably create new dramas though, maybe they can go inboard ............ food for thought.
roji i kind of get what you mean , next time your free could you grab a few more detailed pics of the set up. ?
Do you know what booster yours is off.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
TAZ
State: TAS
Post by TAZ »
If you look in my post, LS1EK you will see how I did my VE bonnet hinges. Basically you weld on a new mounting plate to pick up the holes in the bonnet.
FJWALLY
Post by FJWALLY »
Got frightened... thought the WA mob had come down to NSW and made it as far as the Ettamogah pub at Kellyville :shock: :lol:
FJWALLY
Post by FJWALLY »
Popped up on a facebook page - must of been from before we shut the boarders to those pesky westerners.
Harv wrote: Thu Dec 03, 2020 12:20 pm Got frightened... thought the WA mob had come down to NSW and made it as far as the Ettamogah pub at Kellyville :shock: :lol:
