Red Rattler Revamp
Re: Red Rattler Revamp
Strut (verb): to walk around with ones head held high, as ones bonnet hinges are pretty damn cool :lol:
Only kidding.
greenwagon62
State: QLD
Post by greenwagon62 »
Blacky wrote: Mon Jan 27, 2020 1:20 am Finished product , cost around $120 In bitsImage
A lot smarter than me, I couldn't work out how to use an EK honeypot, so had to use a HT one.
FBIDEK did all the thinking not me Image
Only got an afternoon in today , mounted the battery box up - is out of a VE Commodonor, also painted the boot area and fuel tank ready to all go in - It is FAR easier to install this with no quarter panel on the car ImageImageImageImageImageImageImageImageImage
rosco
Post by rosco »
Just a suggestion, Blacky.
I put a drain tube from the battery tray to outside the vehicle in mine.. lost one battery tray to acid...
rosco wrote: Sun Feb 02, 2020 9:28 pm Just a suggestion, Blacky.
Will be a dry cell Rosco
rosco
Post by rosco »
Tee-totaling car.... not a booze bus, Blacky...
mph
Post by mph »
Good time for some mini tubs while rhe rear panels are off
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
mph wrote: Tue Feb 04, 2020 1:00 pm Good time for some mini tubs while rhe rear panels are off Image
already done sir 8) 8) just across to the rails
mph
Post by mph »
Was there any pics or details or to busy with the hammer.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
no pics, while the diff was out I cut the strip between the rail and the inner out, belted it across and welded it back together again, pretty easy job did them in a night.
mph
Post by mph »
Are they double skinned inner gaurd with an air gap ?
FB-Special
Big block 161 :lol:
Holley sniper EFI.
no - not double skinned, once the cut is made the inner guard will push across to the rail , only gives you another half an inch or so
mph
Post by mph »
No complaints on gaining half an inch.
I'm intrigued would love to see this done close up or pics.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Blacky,
A lot of people seem to cut and shut the whole tub inner wall across, which is quite a bit more work. Seems to me your method be just as effective. As you say the gain is not great, although I've noticed that any rubbing tends to occur above the lip with body roll. Increasing clearance slightly beyond the rail could have some extra benefit.
A picture tells a thousand words !!!!
