A little bit more info on the ally pullies that McGee made (see earlier post of my damage, shiny black painted pulley). My red motor set has a similar pulley on the fuel pump (more on the pump later). The McGee pullies are a 32-tooth unit, 1 7/64“ wide, trapezoidal profile with 3/8" pitch.
A suitable belt is the Gates PowerGrip® timing belt. These have a part number specified by:
1. Length - the length is shown in the first part of the belt designation. The first number is the pitch length, in tenths of an inch. The belt pitch length is normally the length at the belt pitch line (located at the neutral axis near the cord line and varies with cross section and construction). Pitch length should not be confused with:
• Outside belt length (measured with a tapemeasure under no belt tension),
• Inside belt length (measured with flat pulleys or a tape measure and varies with the manufacturer),
• Belt effective length (measured at specified pulley diameter), or
• Nominal belt length (a designated belt length).
Confused? Me too. Often the best way to determine belt length is by trial and error (handy if the belt shop is nearby, friendly and has a good stock of belts… difficult if you are ordering a belt online). As an example, a belt with part number 270L050 has a 27.0" pitch length. Length will vary considerably depending on how the McGee pump is mounted.
2. Pitch - The pitch is the distance from center to center of the teeth (in inches). It is shown in the second part of the belt designation by a letter or letters. The letters correspond to pitches as follows:
• MXL = Mini Extra Light = 0.080" pitch
• XL = Extra Light = 0.200" pitch
• L = Light = 0.375" pitch (this is the pitch that the McGee pulleys use)
• H = Heavy = 0.500" pitch
• XH = Extra Heavy = 0.875" pitch
• XXH = Double Extra Heavy = 1.250" pitch
From our example, part number 270L050 has the correct 0.375" pitch.
3. Width - The width is shown in the last part of the belt designation. Light pitch belts suitable for McGee injection pulleys are available in ½”, ¾” and 1” widths. From our example, part number 270L050 is 0.50" wide. The belt that was supplied with my unit was ½” wide. As this is very much less than the 1 7/64“ pulley width, you can probably get away with not running flanges on the pulley. If the wider ¾” (or 1”) belts are used, the risk of the belt walking off the pulley increases. To counter this when using the wider belts, at least one pulley should have flanges. If the belt is short enough, each of the pulleys can have a flange on one side. When the span (center distance between shafts) is eight times or more the diameter of the smaller pulley, both pulleys should have flanges.
Similar replacement pulleys are available from Naismith Engineering:
https://www.naismith.com.au/list_products.php?m=42
The table below shows their L-profile belts:
- Naismith Engineering L profile pulleys.png (289.2 KiB) Viewed 6862 times
