Clay’s Wedgewood Blue FB Ute
Frame is ready to dress back in shape.Image
Back to the body. I folded up a new support on the bench.ImageAcrylic enamel on the underside. Wiped off flats and zinc rich primer. Axle hump filled, ground, wire wheeled, ranexed and zinc primed.
Started welding in. Time to call it a day.Image
59wagon
Post by 59wagon »
Errol62 wrote:Started welding in. Time to call it a day.Image
You f$&@ed that up Clay. You’ve put fins and a boot on the back of the yoot.
Bloody he’ll Tapatalk is playing up
Have another look John.
This brace ties in the shock mounts so I have done my best to weld through and join the mounts, floor and brace where they cross.
FJWALLY
Post by FJWALLY »
copper jacket hollow point no less - the load of choice for the bunny enthusiast
ardiesse wrote: Sat Feb 24, 2018 6:41 pm It's a rodent.
Or are you talking about the hollow-point?
Bullets mmmm, not enough of them !!!!
Clay what's the magic solution you use to de rust ?
There is a product similar to fish oil by PPC I think, that flows into all the nooks and crannies then dries like paint, that's what I have used in the hard to get at bits. I will get a photo of the tin this arvo.
Bought a 25kg bag of citric acid crystal from rural supplies. Dissolve about one kg in a fish crate or say 5 kg in a large wheely bin. Soak for 24 hours then hit with pressure washer. Then get it dry ASAP either with heat gun or wd40. Doesn’t affect chrome but will remove some paint. Seems ok on rubbers etc. it’s just lemon juice really and non toxic. Great tip from Western Wagon.
Fish oil to the bits you can’t get too like inside box sections. It soaks in to the rust. Cavity wax if there is no rust.
Bit more on the tailgate
ImageAfter wire wheel and soaking in citric some more. Gave it a blast in the car port. Just like a dry windy day st the beach really. Image
I used my $30 blasting gun from Adelaide Tools and $3 worth of dried sand.
I’m lucky I have the van tailgate as a template as this one although rust free is pretty beaten up. I have it all fairly flat now but noticed that the van one has a fold near the top which seems to be all but bashed flat on this one.
Hi Clay excuse my ignorance but isn't the van one like the station wagon which would make it a bit different to the ute ???? I just received an almost perfect station wagon tailgate thanks to Trev in Wonthaggi and looking at it, it is quite different looks to have more cuve to the skin has a piece at the top for the seal to glue to and the inner shape of the frame is different and the top of the skin rolled over further but as I said I have not seen a van one to be able to compare.
Photos of the station wagon tailgate I would be interested to learn the differences.
Neil the van tailgates are identical to ute and nothing like the wagon. This applies to FB EK. FE FC will be a different story as the vans are more like a two door wagon.
Cheers Clay good to know
Welding up the tray and poking around cleaning up the rear floor. Filled up most of the holes, ready for lots of grinding. Found a few small holes in the outboard bottom corners of the cabin rear wall. Scraped, blown and vacuumed out behind the skin atop outer sills between b pillar and rear wheel arch.ImageImageImage
