Chev EK
Re: Chev EK
[quote=Errol62 post_id=234834 time=1537090333 user_id=8012]
Coming together very nicely Greg. You must be getting pretty excited. I know I would be over thinking all those little details and not being able to get to sleep.
Thanks Clay, many sleepless nights behind and in front of me !!![quote=thebrotherj post_id=234836 time=1537090566 user_id=7120]
Amazing work Greg! Can’t believe you had do the front end again... good persistence.
Cheers, Joe
Yep just never happy and a bit obsessive, funny the hunt for perfection has lasted all my life but I still cant find it.
[quote=WesternWagon post_id=234842 time=1537095364 user_id=3547]
Nice work Greg did you use a straightener the lines look very tidy
Gazza
Thanks Gary, yeah I have a ebay special tube bender and the straight bits I just tap with a rubber mallet on a flat piece of wood and it straightens easy.
Re: Chev EK
A bit more fuel line tonight, bugger of a job very time consuming !
Silver pipe is gravity fed from the tank to the pump and the blue is pressure then return.
Got my extended ball joints today so my front end can finally be finished off, the ball joint lifts the top wishbone up by half an inch and makes the car go into camber when cornering, it also clears the wishbone from the brake callipers so I don't have to grind them for clearance. I will do a full update on the front when I finish it over the weekend
By the way these are made for the 1st gen Camaro and surprise surprise are the same as the holdens !!!
More tomorrow
Re: Chev EK
ball joints sound interesting , are the Torana ones the same as HR ?? i.e. - will these ball joints go onto a HR upper wishbone ??
Re: Chev EK
Blacky wrote: Wed Sep 19, 2018 12:18 pm ball joints sound interesting , are the Torana ones the same as HR ?? i.e. - will these ball joints go onto a HR upper wishbone ??
Yes, Holden were all the same HR to HZ I believe, including the Torana's
These are made extended to suit the Camaro, but they fit the Holdens.
gledge
Re: Chev EK
Post by gledge »
Looking killer man where did ya find caltracs for it? Iv never seen them for them before?
TAZ
State: TAS
Re:
Post by TAZ »
EK283 wrote: Sun May 21, 2006 7:13 pm Just an update mates.
I have made a folded section with captive nuts for the new tank to sit in.I have stich welded it and it is very strong with the tank screwed in.
Dam rust! Filler hole filled up. Still not sure about filler tube location.
Boot on for trial fit. The boot gaps are not the best and I can remember it never was. Is this a EK thing or should I try another lid?
Happy building Greg.
Hi Greg can you tell me how much room i need between the rails to fit. F#!d tank? My car has has a rear chassis welded into it so before i go in search of a tank i want to see if one will fit.
Cheers, Simon
Re: Chev EK
gledge wrote: Sun Sep 23, 2018 2:33 pm Looking killer manImage where did ya find caltracs for it? Iv never seen them for them before?
I got them as a kit from Mcdonald bros in Victoria. Of course they have been massaged a bit because I have inverted eyes in the springs. I cut down the bars and modified the spring hangers for them to fit.
Re: Chev EK
Hi Simon,
I will measure tomorrow afternoon
Re: Chev EK
So underneath is pretty much finished bar a couple of clips etc.
There was a couple of days in the fuel and brake lines !!!!!
I started the front end final fit and am happy with the final positioning of the suspension arms, my calipers clear the wishbones and under full compression the top arms sit about 20mm from the inner guards. You can see how the top arm is flat so when you corner the arc pulls the top of the stub axle in and so gives more camber, probably wont notice as I'm not going to race it as such !!!!!
Have to get some washere and bolts tomorrow so I can continue.
TAZ
State: TAS
Re: Chev EK
Post by TAZ »
EK283 wrote: Sun Sep 23, 2018 8:11 pm Hi Simon,
Cheers Greg 👍👍
thebrotherj
Re: Chev EK
Post by thebrotherj »
Tidy, tidy work Greg
Re: Chev EK
Simon,
The tank measures 960mm rear x 800mm and tapers down to 880mm front in the body area, (the part that fits through the hole)
The flange where the bolt holes are is approx 25mm on top of this measurement'
Forgot to say I rotated it from those old photos.
TAZ
State: TAS
Re: Chev EK
Post by TAZ »
cheers Greg, I will check mine to see if one will fit :wink34:
Re: Chev EK
greg did you cut up your first torana crossmember to do the second one? and if not would it be suitable for somebody not as fussy about front end geometry? do you want to sell it?
Re: Chev EK
Hi Mick,
I started to cut it for the brackets but then decided to make new ones.
I will take a pic and post it this arvo.
It really should be cut and redone its just I had found another one quick so went down that path.
