Clay’s Wedgewood Blue FB Ute
Cmon Stephen the factory wasn’t that bad! Cheers mate.
I have to replace the passenger side inner subframe leg. I am trying to decide whether to make up a jig or fit it to the car and weld. I’m leaning towards making a jig do I can get access better.
Previously I have simply recessed about 10mm of the stump then slipped the new leg over and lap welded. Also offsetting top and bottom joins.
Any advice greatly appreciated.
My two cents' worth: Repair instead of replacing. The effort that goes into making a jig is better spent doing the actual repairs. Reviewing your photos on the previous page, the subframe leg doesn't look rotten enough to warrant a cut'n'shut.
Thanks Rob. I’ve been thinking that way a bit.
I love my little craneImage got her up to a comfy working height to do the holes on the front corners of the floor now.
Bit more done. Driver side floor and a pillar bottom is all welded up. ImageImageImageImageNice big drain hole left on the pillar bottom. Couple of patches on the floor in the corner and on the side next to the front seat mount.
thebrotherj
Post by thebrotherj »
Errol62 wrote:Bit more done. Driver side floor and a pillar bottom is all welded up.
Image memories... Image
I sure was happy when I got this section finished on my Ute, good work on keeping your version nice and simple. I certainly didn’t!
Keep on chippin’
Cheers J
Plenty of practice on the van joe
That's the way Clay, you are doing a great job on the old girl.
Its such a shame theses old character cars rust when the modern boring tech filled people movers dont !!!!!!
Patrick_R
Post by Patrick_R »
Devastating find there Clay.
But your the best man for the job mate.
Ric.
A few more little bits. ImageImagenothing devastating. The inner body to subframe mounts needed a good clean out. Image They were chock with dirt and the floor above was starting to rust through. The mounts and body member themselves being thicker steel seem solid.
59wagon
Post by 59wagon »
It’s good stuff chasing the rot, eh Clay? Keep having fun mate
It’ll be great when it’s all banished John!
Hey Clay
Good you are taking care of it now mate you will have piece of mind that she will last another 50.
The places on the gearbox support arch and the like are pretty standard hey get the screw driver out and make sure you find all the suckers.
No time to work on the ute Image
Had the drain snake on the gurney out to unblock the waste this arvo. Put it to work on the subframe and gave it a good flush out. A lot of decomposing vegetable matter came out. Got most of it but can’t get the snake up the inner legs past the engine mount plate bolts. I will have to take them out. Next thing I will be pulling it all apart so I can do it properly.
Cleaned the steering box up at least. ImageImageProlly just leave as is. With my sedan I fitted a grease nipple to the filler plug and just pumped it full of moly. Anyone else have a take on this?
Another thing I am wondering about. Image anyone replaced the nylon trunnions?ImageI have four manual columns here and none of them have these intact. Would certainly tighten things up.
