Clay’s Wedgewood Blue FB Ute
Really flying along there Clay you will have it on the road in no time.
Much awaited wheel cylinders arrived. One guess what size heads on the bleed screws I obtained. Image
Here’s a curiosityImageThe hand brake cable to backing plate mounts are marked L & R. Well some are. No obvious difference but oh well guess I’ll reassemble accordingly.
With the original felt gaskets I salvaged. Imageone has gone missing now of course.
Rears on, fronts assembled. ImageThe brake guys told me they use kopr kote on the adjuster threads and a smear around the inside of the adjuster lid. Just be sparing with it and don’t let it near the pistons.
ImageImageImagedrivers side rear installation complete.
59wagon
Post by 59wagon »
Nice work, mate
Passenger side rear completed today. Next job hook up the handbrake cable. I have a replacement for the pull handle which is broken. Threw some elcheapo black enamel on it this evening. The front cable is good but the adjuster threaded rod is bent slightly and won’t turn. It will all have to come out. Fun fun fun. Waiting for paint to dry on front backing plates before I do the front brakes.
Can’t believe the $1 finish on the handbrake bracket:Image$1.99 on special at supercheap Image
Hang onImage NOT suitable for automotive use wtf?!
59wagon
Post by 59wagon »
Bloody hell, Clay, does that mean your brakes might fail?
Should be right, mate. It’s inside the car.
It’s ok mate I painted the backing plates with a superior product
thebrotherj
Post by thebrotherj »
Looks like you’re having fun Clay
Did you work out why the Red was running hot before the starter gave up?
Something to do with only having about two litres of coolant in the system joe.
thebrotherj
Errol62 wrote:Something to do with only having about two litres of coolant in the system joe.
Ha! That’s a relief then. Maybe try two gallons next time? Image
