what rims
what rims
hi i have a fb and has lj diff.. just wondering what rims to use as spear.. have a ht rim and last time think i tried it hit on leaf springs.. would hk be the go?? any help would be cool
building the dream Rick
Re: what rims
What rims are you currently running? You would be best to have a spare with the same wheel nut taper. HT - HG and FE - HK are different believe it or not.
Re: what rims
not a bad idea , im running a lj diff as well and should double check as well in case of a flat
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Big block 161
Holley sniper EFI.
Re: what rims
standard rim will get you out of trouble
Re: what rims
i am running convo pro.. man just got rid of a standard rim. will look in to get one again
but will it fit on the front hr dic
Re: what rims
HR discs and calipers at the front?
The original rims will fit over LJ drums at the rear, but they're no good for the front. Best option is four HD/HR wheels. Torana rims have the wrong offset for HR discs, and they'll scrape on the tie rod end and upper ball joint.
But if you are running LC/LJ discs and calipers on HR stub axles, then you'll be OK with Torana rims all round.
