EK windscreen washers
Post original documentation here
Craig Allardyce
Post by Craig Allardyce »
Not sure if it exists but would anyone have fitting instructions for vacuum windscreen washers to an EK? I'm trying to find the right spot where the nozzle is fitted in the bonnet. Also looking for info on the valve that was fitted to the inlet manifold ( I'm assuming it was a one way valve for backfire protection)
Thanks.
Re: EK windscreen washers
G'day Craig,
I've got the destructions for the FB and EJ foot-operated washers, FE/FC vacuum operated washers, and EH electric washers. Not sure if these help you though?
Haven't seen a check valve in the vacuum lines. The diaphragms have a hard enough time with ageing, let along the odd manifold pop.
Craig Allardyce
Thanks Andrew.
The check valve is pictured in the guide (Tim Galls car). I have seen them before but not recently. I'm just looking for a dimension to get the squirter in the right spot. Measure once, drill twice.... :wtf:
My EK wagon had (and still has) the single hole for the squirter. No guarantee it is in the "NASCO approved" position, but looks right. I can measure it this weekend if it helps.
Craig Allardyce
Thanks Andrew that would be great. :thumbsup:
Measured it up over the weekend. From the trailing (rearmost) edge of the bonnet to the centre of the mounting hole is 8.75".
Craig Allardyce
Cheers mate. Appreciate the help. :thumbsup:
