HR disc brake front end
Mick21
Post by Mick21 »
Does anyone know where I can get a HR disc brake front end?
oz_ek
Re: HR disc brake front end
Post by oz_ek »
I see one on 'evil bay' in Melbourne, Looks a bit tired and rusty for $1100-
Mick21
Post by Mick21 »
Yeah saw that one too. Bit rich for the condition it's in and then I still have to do full reconditioning.
Thanks any way
oz_ek
Post by oz_ek »
Have you considered Torana discs on a drum brake HR front end?... The adaptor kit is readily available.....Only draw back is the conversion makes the track width a little wider.
DOLLER60
Post by DOLLER60 »
Better off with P76 discs and HQ calipers- narrows the track :wink:
fb delivery
Post by fb delivery »
HR Drum brake front end $300
pick up Toowoomba
4 cylinder VB Commodore also an option if you want to retain 4.25" pcd as per FE - HG.
Mick21
Post by Mick21 »
Wow, thats starting to sound a bit too complicated.
I'm in Melb so Towoomba pick up is a little far.
I'll either keep it original or just wait for a HR front end to appear.
Thanks
There is one on Gumtree. Not sure what your budget is, advertised for $750 incl booster.
http://www.gumtree.com.au/s-ad/willowba ... 1105872639
kelleigh54
Post by kelleigh54 »
Bought a drum brake unit with everything hanging off it for $150 a couple of months back , will be using HQ / WB spindle and rotor set up with rotors drilled to early PCD . Will do full rebuild and modify top A arm location to install in daughters EJ . There are sensible buys out there , personally I wouldn't pay more than $250 for a rebuilder .
Not mine, though one for sale in WA, over at the Ozrodders site:
http://www.ozrodders.com/forum/viewtopi ... =9&t=61348
HR DISKBRAKE FRONT END
SUIT RESTORE
IN BITS READY..
$650 ONO..
0414066155
SMS FOR PHOTOS CANT UPLOAD..FILE TO BIG??????????????????
KILRFB
Post by KILRFB »
Not sure if you are still chasing one but I have a disc brake version for sale as I have purchased a rodtech frontend. It is stripped down but complete and has had the hr outrigger removed. I have a brand new fb outrigger for it. I have done the lower cross member re-enforcement plate already. It comes with new ball joints replaced and about $400 worth of new parts not fitted. Will need new shockers and the callipers rebuilt. Chasing $800 no less. I'm in Kilsyth.
If anyone needs a HR front end in WA I have one you can have for a bloody sight less than $650 .......
