Help Identifying Front End
- Craig Allardyce
- State: VIC
Re: Help Identifying Front End
If that's toe out at full lock it looks ok. i.e inside wheel turns in tighter and assuming you toe in at straight ahead is correct (wit car on the ground).
bat53retro
no commodore came with u bolts to hold the rack
rack could be austin 1800 !!!!
Looks like this is getting more and more complex, I might have to start from scratch
Dirty Grey
Hi Ben from what I can see I think it is an HR front end fitted with HQ style brakes and HG steering arms, the rack at a guess would be Austin 1800. The whole set up looks a bit dodgy to me, the brake hose rubbing on the tire, the routing of the brake hose and what looks like a commodore rim fitted to HQ brake.More pictures would help. cheers Rex
