Heya knowledgeable Holden guys,
i want to wire in an Wilson ammeter into the EJ.
Would some one have fitting instructions for wilsonia gauges by chance? I know they are more common for the FE/FC crew, but thought i would try here.
What i have seen so far is + at starter motor and B+ at regulator - using 30A wire. Would this seem correct?
thanks in advance
Dan
Ammeter - wiring instructions
- Craig Allardyce
- State: VIC
Re: Ammeter - wiring instructions
Must be in series, not parallel, i.e. all current flow from the starter battery connection must go though the ammeter to the positive on the regulator. I would also fit a fuse.
A little late edit here, no starter motor current should go through the ammeter! Otherwise you'll need Blacky's fire extinguisher.
Last edited by Craig Allardyce on Tue Jan 26, 2016 7:27 am, edited 2 times in total.
........ and a fire extinguisher
Been there. You might want to consider fitting a volt meter. Much safer.
Hmmm all this talk about fires is somewhat concerning. But I assume it's safe IF wired correctly so that there is no starter motor current AND a fuse?
Thanks all for the advice so far
Dan
Dan
How'd you go with the ammeter Dan? I just remember melting the insulation off wiring when I installed one in my HX van way back in 82.
