K&N airfilter to suit 138 stromys
G'day peeps does anyone no if k&n Do a little air filter assembly to suit a twin stromy set up on a grey? Part numbers would be great so I can do some more google research thanks.
Re: K&N airfilter to suit 138 stromys
Quaddy,
As far as I know, K&N does not do an entre filter assembly to suit the Stromberg carb. They only do replacement filter elements.
There are a number of manufacturers who make the air filter bases/lids. One example is AussieSpeed:
http://www.aussiespeedshop.com/product/ ... -516-neck/
When hunting down a base/lid, bear in mind that the neck of the standard B-model Stromberg is 2 9/32” diameter, though some of the castings are slightly larger (getting to be 2 19/64”). The WW Stromberg neck is larger at 25/8” diameter.
Once you have a base/lid, you can replace the element with a K&N one. This website lets you enter dimensions to suit your base/lid, and then searches out the range of K&N part numbers:
http://www.knfilters.com/search/univ2.aspx?id=S0001
