Stewart
Chrome plating exterior door handles
- Contact:
Re: Chrome plating exterior door handles
Hey thanks everyone. I'm learning new stuff all the time with my rebuild so if I can help others too and keep as many FB EKs on the road that's even better.
Stewart
Stewart
I had a play with one of my handle assemblies about 30 years ago..... and found that the scuffing on the button was caused by the push-rod bearing being worn.... you might like to look at those - and even better..... come up with something which ensures a deeper "boss" for the pushrod to work on...... just my thoughts...
Walla Pete
I've punched out the pin but the barrel is not coming out. Any suggestions?
thanks Pete.
thanks Pete.
- Contact:
Can you use the key and turn the barrel to loosen it up and maybe some WD-40?
- BILLY BLACKARROW
I am going to buy new from Rares at $71.50 ea its a lot less hassle
Billy
Billy
BILLY BLACKARROW
- Contact:
I had my door handles rechromed with a whole stack of other stuff so the for the cost of a new spring and O ring it worked out cheaper than buying 4 new handles...I am going to buy new from Rares at $71.50 ea its a lot less hassle
The barrel Walla Pete is referring to is for the station wagon rear tailgate handle...I don't think Rares sell these...
I don't have any experience with this barrel inside the handle issue with cars - but can tell you a bit about it with the front bootlid on a caravan.... grrrrrr.
The one on the caravan is probably similar in design as for mounting/retaining.
Water gets in and what doesn't flow into the boot, sits in a dam to rust the barrel to the body of the handle.
When I did get it out, I put a thin coating on the outside of it with Loctite 76769 silver paste - this stuff is brilliant for fitting dis-similar metals.... especially stainless into alloy... but, it costs a fortune.... one tub will probably outlive you though...
I fitted two "O" rings around the shaft to stop the leak - then ground out a relief drain (1/16th") to the base of the handle body.
I did pull out the barrel inside the holder on the boot-lid on my old bus.
I did exactly the same thing to it.... grinding a relief drain port and coating with 76769 but I did not fit "O" rings.
As Stewart posts - if you are going to have any re-chroming done... it may prove more cost efficient to throw it in with the bundle and get a locksmith to find a barrel to suit...... and have the lock key aligned with the rest of the car.
