front suspension springs
EK 308 Uterus
Post by EK 308 Uterus »
Gday to all.
I am finding the extra weight of the 308 fitted to my EK has made the tyres rub in the inside of the guard.
I have heard you can put packing plates on the top of the springs to give some extra lift ...but not sure? The frontend is recessed HR, I could go to somewhere like pedders suspensions and spend a #%$@ load of $$$ but would like to avoid that if possible ...any suggestions. Help
Luke
Mephious
Post by Mephious »
I can only offer the following mate, hopefully others can offer more advice as I dare say I will be facing a similar problem.
- Change ride hieght ..... new springs
- Change tyre offset/width ...... new rubber and rims
- Lip front guards ......
Dont know about the backing plates sorry.
Gday Luke
I have heard of spacers being placed above the springs in the front end.
They use to do it on the old gassers back in the sixties at the drags.
A higher front end, meant better weight transfer for the launch.
The spacer was an aluminium disc of similar diameters to the inside & outside
of the spring, made to fit snug in the spring tower.
The height of it was by however much lift you wanted.
Its an option :shock:
Jeff
captainbill
Post by captainbill »
got the same problem.just bought some nolathane spacers that fit under your springs.
captainbill
Those nolathane rubbers are 8mm thick,you place them under your spring.they should give you a little more hieght.I have not put mine in yet so dont know how good they work.Think there about $50.Speed shops or rare spares should have them.I also trimmed the inside of my gaurds a bit.Im also fitting a new thicker front stabaliser bar.These are not overated and play a big part in stopping the body roll which can also make your front wheels rub.
Malcolm
Post by Malcolm »
Hey Luke,
If your suspension has come down a fair bit with the extra weight, it might be worth getting a wheel alignment done as when the front comes down the top of the tyres goes out at the same time. Hense needing a wheel alignment to stop the tyres scrubbing.
If you replace springs or fit spacers it would still be a good idea to get an alignment done.
cheers
Malcolm W.
EK 308 Uterus
thanks for reply
I appreciate the imput guys, I have fitted 16 inch speedy rims and new low profile rubber. ( I had not considered the wheel alignment factor thou ) I was going to get an alignment when she was just about complete.
I need to get about 2 cm lift to clear the guard.
I dont think those shims will do what I want.
I will have to pull out the springs and take them to pedders and see what they can supply.
Thanks again
Luke
ipg
Post by ipg »
spring insulators
rare spares part number 7429151
these are hard plastic and are 4mm thick
so will raise your front end 8mm
i think they were 6 bucks each :shock:
go to clarks rubber!
