1962ek's fire express
Re: 1962ek's fire express
1962ek wrote:No Mick not at all, this build has taken me 27 months and I didn't pick it up on ebay.
All my own colors and not copied.
Graham
wasn't sujesting any of that just asking :thumbsup: as like i said in the pics (things can vary considerably when seen in person) it looks the same colour and also same colour trim, the other one had same but different wheels 17" showwheels, no visor, no scratch plates and don't think it had side chrome and pretty sure it had a bench seat
choppedfan
Post by choppedfan »
Graham,
You have absolutely nailed the "look", it's perfect :thumbsup: :thumbsup: :thumbsup:
Goodluck with the engineer, this car needs to be cruising the streets and turning heads.
Mick 8)
1962ek
Post by 1962ek »
Thanks for the comment Mick, unfortunately it failed the brake test today. You can't combine VY front brakes with VN rear brakes. Front works too good with the twin cylinders and the back hardly works at all, only registered 18% . Needed at least 25% to pass, so back to the drawing board. Obviously bigger is not better. Everything else passed with flying colours so another trip is needed :ughh:
They certainly know how to charge up there, Exhaust emmission test took 5 minutes =$75.00 Brake test took 1hr 20min = $400 and the list will go on.
Will keep posting. Graham
bumper
State: TAS
Post by bumper »
If you were to run a proportioning valve that would fix your drama wouldn't it?
Btw I love your car looks sweet,
Mind me asking a few questions?
Hope not :shifty:
What pedal box/booster/master are you running?
This is the car mick was referring too, I had someone look at it for me as I was thinking of buying it, wasn't as good as the pics showed!
wanker????
FBEKHOLDENFANS page
FBeing
Post by FBeing »
Nice ride!
I've got a quick question - what width and profile rubber are you running?
1962ek
Post by 1962ek »
G'day Bumper and FBing, in answer to your questions.
I used the original pedal box and relocated the brake to the clutch side with a modified pedal from my VY donar car. Used a VN booster and master as per V6 conversions recomendation.They supplied the mounting bracket.
FBing. Am running 185 x 65 x 15 on 6in dragways with commodore stud pattern. this gives plenty of clearance on the rear and no problems with the steer and turn circle.
bumper
State: TAS
Post by bumper »
If you could take a pic of the booster setup it would be greatly apreciated mate, cheers
wanker????
FBEKHOLDENFANS page
do you have to pay for the brake test again? the local engineers to me charge every time they do the brake test @ $500 a shot fail or pass :thumbsdown: luckily I can travel a bit further to other engineers that only charge once :thumbsup: also one of the engineers local to me was saying he's had to knock back cars that have failed the test that have all the right stuff big and fancy brakes yet have failed because it's all brand new and not bedded in and fails that would suck
BILLY BLACKARROW
Post by BILLY BLACKARROW »
I am useing hz holden all round with boosted front proportioning valve and was told by engineer ( Athol )that it wouldn't need brake test as it a proven set up.
BILLY :arrow:
BILLY BLACKARROW
EK JAY
Post by EK JAY »
Yep apparently its up to the engineer's discression like billy's engineer said if its a tried and proven
set up all matching brakes / booster eg hq hz commodore matching you wont need a test as they go off
allready attained data apparently
although depends on the engineer he may still want one done so probably ask your enginners guys if he will need a brake test
with what ever brakes your using or does the tried and tested clause apply to your set up
EK JAY SINCE 1990
gazza
Post by gazza »
G,day all.What size is the vn master cylinder is it 15/16 or 1inch.If you are using the 15/16 master on the twin spot calipers they might be taking all the brake pressure and you have not got enough pressure to operate the rear and you may need the 1inch master to give the same pressure all round.But i could be wrong.I am using vt booster and master which is a 1inch ve front calipers which have twin piston which are small and vn rear.I hope i dont have the same problem as you.cheers Gazza
1962ek
Post by 1962ek »
Hey Bumper, I gave you the wrong info on the booster and master. I should have said VC V8 master and booster.
Today we changed to VS stubbs roters and calipers, and hopefully fix the problem.
When going for engineering it's best to have a proven combination as Jay said.
The engineer said the same thing. As soon as we mentioned the mix n match set up, he insisted on the brake test, mainly to cover HIS arse. This bloke takes pics of all the mods on the car and any other things that seem to be modified. That way if you change anything after it has been passed it all comes back to you, not him.
Don't lie to them about what you have done, be upfront and you wont get caught out, they hate being lied to. We got this info from a bloke that was booked in before us and said DON'T argue with him.Remember the old saying, Rule No1-- The boss is always right, Rule No 2--- If the boss is wrong, refer rule No 1
Hope this will help you guys later on. cheers Graham
1962ek
Post by 1962ek »
G'day Mick, to answer you question, yes, I will have to pay for a second brake test. He said he went easy on me for the first one ,knowing that I have to come back for a second one :ughh:
If I knew of another one close by I'd go there next time. Have to make some enquiries.
Cheers Graham
thanks, that sucks and one of the downfalls with the new engineers, it was sposed to be a better system but it's more all over the place with what seems like absolutely no consistency now
1962ek
Post by 1962ek »
Well, if we want to modify our cars Mick, we'll have to play their little games.
I think this bloke in Ballina is IN with these other blokes(he gave me their numbers) and they believe that we will pay whatever, just to have the vehicles passed. :silent:
