Rare Spares door hinge bolt kits - anyone used them?
steved57
Post by steved57 »
Hi all
I've bought a set of door hinge bolt kits from Rare Spares for the EK. Problem is the front door kits (FK1008) have slotted screws for where the hinge mounts to the pillar and the rear door kits (FK1009) have Phillips head screws for the same thing. I can't imagine that Holden used two different type of screws for the same purpose (though I've been wrong before) so has anyone else experienced this please - or did the cars originally come with two different types of screw?
Cheers, Steve
Les
Re: Rare Spares door hinge bolt kits - anyone used them?
Post by Les »
steved57 wrote:Hi all
Cheers, Steve
They should have 6 slotted screws it would appear the we may have a stock mix up thanks for pointing it out. If you give me your name and address I will send you some I can be contacted at lmcveigh@rsp.net.au
Les
If you have any part enquiries or problems that cannot be solved by going to http://www.rarespares.net.au please contact me at lmcveigh@rarespares.net.au
so you are talking about the front door hinge to the A pillar bolts? they should be normal hex head 5/16th UNF bolts not screws
steved57
Post by steved57 »
Thanks Les & Mick. PM sent you Les. Cheers, Steve :thumbsup: :silent:
