HR front end
bat53retro
Re: HR front end
i think the reason for the gap from the rubber to the subframe is to pretension the anti dive on the crossmember
- BILLY BLACKARROW
Re: HR front end
Next Question
How tight do I do ALL the ball joint nuts up / is there a torque setting or do you just do them up firm. The hole for the split pin doesn't want to line up it's to low for the slots in the nut ::: can I use NYLEX LOCK nuts ????
BILLY
DUMB ASS
BILLY
BILLY BLACKARROW
Re: HR front end
Tighten them up until you fart ,then back them off until the split pin will go through - its not rocket surgery.BILLY BLACKARROW wrote:Next Question
BILLYDUMB ASS
- BILLY BLACKARROW
Re: HR front end
Blacky I like your torque settings
but the problem is i cant tighten it enough to get down to the hole for the split pin
BILLY
BILLY
BILLY BLACKARROW
Re: HR front end
This may sound stupid , but you arent putting them in the wrong way are you ? The holes are tapered ................
- BILLY BLACKARROW
Re: HR front end
No they are the right way
BILLY BLACKARROW
Re: HR front end
Pretty sure the spindles have 2 holes 45deg around from the other.
- BILLY BLACKARROW
Re: HR front end
I will have a look at that today. It is the upper & lower ball joints on the drivers side I am having all the trouble with
BILLY
BILLY
BILLY BLACKARROW
Re: HR front end
Eeeerrrrr, maybe I should read things properly I thought you were talking about spindles
, not sure about ball joint holes.
Re: HR front end
and I thought he was talking about tie rod endsTrev wrote:Eeeerrrrr, maybe I should read things properly I thought you were talking about spindles, not sure about ball joint holes.
If nylocs fit then whack 'em on , a lot of aftermarket ball joints have nyloc nuts on them anyway...
Re: HR front end
I've had balljoints before with nylocs and no hole for split pin that is the way they came, although I did return them as I didn't trust the nyloc and have the same issue where it wouldn't tighten enough but it was just enough to get a smaller split pin in
- BILLY BLACKARROW
Re: HR front end
Well I have had some success to day I have managed to get the split pins in I am not sure whether the ball was turning as I tightened it up or not but they are in,It feels bloody heavy and its not on its wheels yet I am hoping it will ride up with wear (as the old Taylor's used to say.)
Good Job I am not working for a Boss
BILLY
BILLY
BILLY BLACKARROW
