Fuel Sender Repair
Marko
Fuel Sender Repair
Post by Marko »
Sorry guys, possibly a silly question to some, but
As per the thread regarding how to rebuild a fuel sender unit, does it matter what type of metal the rivets are made of when rebuilding the unit.
I would have posted this on the thread itself, but it seems more of an info thread rather than posting thread.
I have taken the van for a few runs now, and as usual a few maintenance things are poping up.
Off work tomorow so this is my list
1 rebuild fuel sender - my idiot light doesnt work on the dash, I assume it is a sender unit issue
2 replace broken handbrake cable - rear section
3 repair minor leak in thermostat housing
4 replace gasket on trimatic pan - minor leak
Should be fun, finally getting my hands dirty.
Mark :thumbsup:
FBVANDAM
Re: Fuel Sender Repair
cant remember offhand, dont they need to be blind rivets ? Aluminium or stainless would be fine I would think ..
What Blacky said...
Scotty did a good how to on this...http://www.fbekholden.com/forum/viewtop ... =25&t=7469
Stewart
Marko
Post by Marko »
Cheers Stewart, that was the thread I was refering to.
Did as Scotty said, but still not working -
Pictured below is a spare fuel guage I have - wondering if anyone can describe where the wires should be, power, earth etc.
On the one in my dash there is only a single wire to the curly contact between both pins (sorry for the lack of proper terminalogy) - is this right.
IMAG0075 (500x333).jpg (190.35 KiB) Viewed 850 times
The spare guage is reading full and its not even in a car ??? - might not try using this one.
FBVANDAM
Doc Bob
Post by Doc Bob »
Sorry 'bout being a bit short on time this morning Marko....had a '36 tudor on the hoist and the boss in my ear!
Have you tried earthing out the wire from the sender to ground?
With the ignition switched to "ON", take the wire off the sender and touch it to a good earth on the body.
If the gauge goes to "FULL", you know that it is definitely a fault with the sender.
If the gauge does not move.........I'd be looking to replace that!
For memory, the wire to the fuel gauge under the dash is as follows...........
PINK +Positive feed off the "ON" position from the ignition.
BROWN - EARTH feed from the tank sender.
GREY + positive dash lighting.
Will give you a call back tomorrow to discuss the other issues.
Best of luck..........Bob.
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
Marko
Post by Marko »
Cheers Bob, thanks for your advice, it worked a treat.
All sorted, fuel guage working.
I will catch you up on the inlet manifold and engine tidy shortley.
Thanks again. Mark :thumbsup:
FBVANDAM
Doc Bob
Post by Doc Bob »
No worries Mark :thumbsup:
Have a couple of manifolds here if you wanna get a permit one weekend and come and get them swapped over.....and any other jobs that need doing!
Great to hear the fuel gauge saga is sorted, should have the thing regoed in no time :D
All the best...................Bob.
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
