Grecian White/Apache Red 225
BILLY BLACKARROW
Post by BILLY BLACKARROW »
I am getting close to paint myself hope it turns out as good
BILLY :arrow:
BILLY BLACKARROW
As Spilt Enz would say..."I see red!"
:thumbsup:
Craig Allardyce
Post by Craig Allardyce »
Thanks guys.
I keep thinking just maybe I might make it to the Nationals this year as I can feel a blood rush coming on after this milestone!! :!: :P :think: :think:
My other head tells me not to rush it and screw something up in the process :egeek:
WayneXG95
Post by WayneXG95 »
If mines Milkshake that has to be Strawberries and Cream. :D
Craig Allardyce
SunnyTim wrote:P.S. Where did you buy your rings and bearings? I am thinking about doing a bottom end....
Tim
I didn't buy them Tim. The engine that they failed in i had built by rpm engines some time ago as i didn't have time to do it myself back then. I'll be getting my replacements thru .hm engines.
Craig Allardyce
WayneXG95 wrote:If mines Milkshake that has to be Strawberries and Cream. :D
Good one Wayne :clap: :lol: :lol: :lol:
I like it! :thumbsup: :thumbsup:
Craig Allardyce
SunnyTim wrote:
Tim
OK sory I thought you were already rebuilding it yourself as you were showing the failed parts.
Tim
No worries Tim. I'm doing it myself this time, I'm just at the strip down stage, although it was to only do the work for the full flow oil filter system till i found my bearing problem. Hopefully in the next few weeks I'll get that all done and I'll get started with the repair come rebuild.
Craig Allardyce
Finally a good win on ebay. Now I can do my own alignments with a few other tools to go.
http://www.ebay.com.au/itm/111044228377 ... 1497.l2649
seen these go for a shitload more. Will cost me about $140 AUD all up. :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Craig Allardyce
For all the picture hungry mob out there :wtf: :wtf: :wtf:
Cheers :wave:
Last edited by Craig Allardyce on Thu Apr 11, 2013 8:50 pm, edited 1 time in total.
Craig Allardyce
Cal wrote:Looks great. :thumbsup:
How many coats of basecoat?
Sorry mate, I missed your post.................just one base coat and 3 top coats.
Yum strawberry creams! Looks great Craig. Once the stainless and chrome goes on you'll have to wear sunnies to look at it... :ebiggrin: :thumbsup:
Craig Allardyce
A bit more work today. Cleaned up all the door strikers and catches and almost finished the tube work for the full flow oil filter setup but ran out of tube! (measure twice.........) :roll: :roll:
Cheers. :wave: :wave:
MeFB
Post by MeFB »
Loving the full-flow conversion :thumbsup: Those pictures are great for anyone else that wants to do the same thing.
I've read how-to's that talk about routing the oil pump discharge pipe out through the sump, but that seemed like a pretty fiddly way of doing it. I reckon I'd do exactly what you've done now that I've seen your pics.
:arrow: :D
Alan
FeeBee
Post by FeeBee »
Love the colour scheme! Can only imagine how good the chrome will look when its back on
He who dies with the most toys wins!!
Craig Allardyce
MeFB wrote:Loving the full-flow conversion :thumbsup: Those pictures are great for anyone else that wants to do the same thing.
:arrow: :D
Thanks Alan. I finished the tube work today and shimmed up the oil pump relief valve 3/16".
The plan from here is to finish building and assembling the engine and do a static test run with the lube system. I have a dummy distributor that has had the drive gear removed from the shaft. I use this distributor fitted in the engine and I drive it with a heavy slow speed electric drill. This serves the purpose of priming the engine before actually running it, as well as it will give me an idea if I will have any major pressure loss across the system from the all the tube work and filter. I'm still uncertain as to how it will go as there is no real way to tell how much oil the engine will flow without actually rotating crank/cam at the required speeds. I'm still working out the best option for oil filters regarding micron ratings, beta efficiency, flow rates, etc. I have managed to find a suitable filter that has an anti-drain back valve and anti-syphoning valve (suitable for a vertical filter). My basic thinking is that I'm filtering all the oil now as opposed to the old bypass system which is a huge improvement so I can be a little lenient with the micron rating. I wont go into my technical thinking as that side just wants to engineer the crap out of it. :egeek: :egeek: I now just have to balance my filter restriction versus flow. At this stage 30 to 40 micron is the go with about 7-8 gpm flow rate. hopefully that will be ok.
Anyway I'm ranting, I'll post some results when its done......and pics of course!
Last edited by Craig Allardyce on Mon Apr 15, 2013 9:09 pm, edited 1 time in total.
