BILLY
Grecian White/Apache Red 225
- BILLY BLACKARROW
I am getting close to paint myself hope it turns out as good
BILLY
BILLY
BILLY BLACKARROW
- Contact:
As Spilt Enz would say..."I see red!"
- Craig Allardyce
- State: VIC
Thanks guys.
I keep thinking just maybe I might make it to the Nationals this year as I can feel a blood rush coming on after this milestone!!
My other head tells me not to rush it and screw something up in the process
If mines Milkshake that has to be Strawberries and Cream.
- Craig Allardyce
- State: VIC
I didn't buy them Tim. The engine that they failed in i had built by rpm engines some time ago as i didn't have time to do it myself back then. I'll be getting my replacements thru .hm engines.SunnyTim wrote:P.S. Where did you buy your rings and bearings? I am thinking about doing a bottom end....
Tim
- Craig Allardyce
- State: VIC
Good one WayneWayneXG95 wrote:If mines Milkshake that has to be Strawberries and Cream.
I like it!
- Craig Allardyce
- State: VIC
No worries Tim. I'm doing it myself this time, I'm just at the strip down stage, although it was to only do the work for the full flow oil filter system till i found my bearing problem. Hopefully in the next few weeks I'll get that all done and I'll get started with the repair come rebuild.SunnyTim wrote:OK sory I thought you were already rebuilding it yourself as you were showing the failed parts.Craig Allardyce wrote:I didn't buy them Tim. The engine that they failed in i had built by rpm engines some time ago as i didn't have time to do it myself back then. I'll be getting my replacements thru .hm engines.SunnyTim wrote:P.S. Where did you buy your rings and bearings? I am thinking about doing a bottom end....
Tim
Tim
- Craig Allardyce
- State: VIC
Finally a good win on ebay. Now I can do my own alignments with a few other tools to go.
http://www.ebay.com.au/itm/111044228377 ... 1497.l2649
seen these go for a shitload more. Will cost me about $140 AUD all up.
- Craig Allardyce
- State: VIC
For all the picture hungry mob out there
Last edited by Craig Allardyce on Thu Apr 11, 2013 8:50 pm, edited 1 time in total.
- Craig Allardyce
- State: VIC
Sorry mate, I missed your post.................just one base coat and 3 top coats.Cal wrote:Looks great.![]()
How many coats of basecoat?
- Contact:
Yum strawberry creams! Looks great Craig. Once the stainless and chrome goes on you'll have to wear sunnies to look at it...hungry mob out there
- Craig Allardyce
- State: VIC
A bit more work today. Cleaned up all the door strikers and catches and almost finished the tube work for the full flow oil filter setup but ran out of tube! (measure twice.........)
Cheers.
Cheers.
Loving the full-flow conversion
Those pictures are great for anyone else that wants to do the same thing.
I've read how-to's that talk about routing the oil pump discharge pipe out through the sump, but that seemed like a pretty fiddly way of doing it. I reckon I'd do exactly what you've done now that I've seen your pics.
Alan
sweet!)
Love the colour scheme! Can only imagine how good the chrome will look when its back on
He who dies with the most toys wins!!
- Craig Allardyce
- State: VIC
Thanks Alan. I finished the tube work today and shimmed up the oil pump relief valve 3/16".MeFB wrote:Loving the full-flow conversionThose pictures are great for anyone else that wants to do the same thing.
The plan from here is to finish building and assembling the engine and do a static test run with the lube system. I have a dummy distributor that has had the drive gear removed from the shaft. I use this distributor fitted in the engine and I drive it with a heavy slow speed electric drill. This serves the purpose of priming the engine before actually running it, as well as it will give me an idea if I will have any major pressure loss across the system from the all the tube work and filter. I'm still uncertain as to how it will go as there is no real way to tell how much oil the engine will flow without actually rotating crank/cam at the required speeds. I'm still working out the best option for oil filters regarding micron ratings, beta efficiency, flow rates, etc. I have managed to find a suitable filter that has an anti-drain back valve and anti-syphoning valve (suitable for a vertical filter). My basic thinking is that I'm filtering all the oil now as opposed to the old bypass system which is a huge improvement so I can be a little lenient with the micron rating. I wont go into my technical thinking as that side just wants to engineer the crap out of it.
Anyway I'm ranting, I'll post some results when its done......and pics of course!
Last edited by Craig Allardyce on Mon Apr 15, 2013 9:09 pm, edited 1 time in total.
