Moderators: reidy , Blacky
Coopa
Posts: 117 Joined: Wed Sep 26, 2012 7:59 pm
Post
by Coopa » Tue Jan 22, 2013 7:23 pm
Hi all I have grabbed a drum brake HR front for my EK sedan.
To upgrade to disc can I use a complete assembly from a HQ, knowing that the stud pattern will change and I will need 14" wheels, if the complete HQ assembly can be used does any thing else need to be modded or purchased (other than master cyl & booster) and what will it do to the wheel offset??
Is there a better option???
Thanks in Advance
Matt, aka Coopa
Post
by Trev » Tue Jan 22, 2013 8:21 pm
I recon the upgrade to Hktg disc brakes are great and you keep the early stud pattern, Trev.
Coopa
Post
by Coopa » Tue Jan 22, 2013 8:39 pm
Thanks Trev
Go the complete HKtG setup (stubs, discs, calipers, hub, backing plate) ?
Post
by Trev » Tue Jan 22, 2013 9:01 pm
Yes the complete setup, not that hard to come by either.
fb cruisin
Posts: 522 Joined: Mon Aug 14, 2006 6:51 pm
Post
by fb cruisin » Wed Jan 23, 2013 12:46 am
Do HKTG rotors and calipers fit HR disc stubs ?
______________
living the dream.
Post
by Trev » Wed Jan 23, 2013 6:33 am
99% sure they do fit.
Coopa
Post
by Coopa » Wed Jan 23, 2013 8:51 am
Thanks Trev
