testing
searsy
Re: testing
Post by searsy »
the rocket wrote:what are you doing with the old pipes?
I am giving them to the leaping seal he reckons he used to play the bag pipes
No my brother or schmeagain will end up with
Sorry
the rocket
Re: testing
Post by the rocket »
no worries thanks.
searsy
Re: testing
Post by searsy »
Finally got some more time on the old and finished tacking the log headers
Time to pull the motor again and weld some unwanted holes
shmeagain
Re: testing
Post by shmeagain »
ITS SHMEAGAIN SWEET mate ill pick them up tomorow :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: thay look good 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
searsy
Re: testing
Post by searsy »
Went over to schmeagains place on the weekend and cut some bits out of his windowless honey beige panelvan
The trimed them to size and had my first go at mig welding
Not to bad for a beginner
muza
Re: testing
Post by muza »
Looks like nothing wrong with that mate! :thumbsup:
Stock as a rock
Not so stock
shmeagain
Re: testing
Post by shmeagain »
searsy wrote:Went over to schmeagains place on the weekend and cut some bits out of his windowless honey beige panelvan
ITS SHMAGAIN SHMEAGAIN SHMEAGIAN Looks good man 8) 8) 8) 8) 8) 8)
searsy
Re: testing
Post by searsy »
Any one used procomp alloy heads on a chev v8 etc
basic.green
Re: testing
Post by basic.green »
on some sites they call them poo comp :roll:
the heads that are on you car now are pretty good all match ported big valves and so on 8)
i dont think you need them but your car mate
building the dream Rick
searsy
Re: testing
Post by searsy »
basic.green wrote:on some sites they call them poo comp :roll:
I actually pulled the engine down and found the heads were ported to much and water is leaking into the valley
Just another in a list of many things that have had to be fixed replaced on the old girl
Sometimes I feel like putting a match to it but hey that's what you get when you buy sight unseen
Then again that's cars :( :twisted: :oops: :?: :thumbsdown: :thumbsup: :thumbsdown: :D
Re: testing
Hey Searsy,
I'm not sure that porting will cause water leaks unless the heads are cracked ? If the heads are milled/faced to much (usually to gain compression) then the ports sit lower and that can cause the manifold to sit high and not seal right. Normally you have to machine the manifold to make it sit lower in the valley to match the heads. Also sealing around the water jackets with silicon is needed. Mate its all a matter of measurement and can catch a lot of people out :shock: :shock:
Anyway your work is coming along nicely.
searsy
Re: testing
Post by searsy »
EK283 wrote:Hey Searsy,
Thanks Greg there is a brazed area in the head near one of the ports and water jackets
I can get this repaired and the heads recoed for $550 or I can get some pro comp heads for $750
The way I am leaning is the smaller pro comp heads and a hydraulic cam as I have never been a fan of solid cams on a daily
I have also replaced the stall from 4500 to a 2500 job
Just would like to make it a more streetable car
Have you had any experience with pro comp gear
fingers
Re: testing
Post by fingers »
gards Greg[/quote]
Have you had any experience with pro comp gear[/quote]
Hey searsy check out edelbrock heads at Summit racing in the States .........I bought a complete 420hp power pack and roller rockers a few months ago for under $2000.00 landed ........the heads were around $1000.00 for the pair ...FYI mate :thumbsup: :thumbsup: ...Fingers
searsy
Re: testing
Post by searsy »
Spent a few more hours welding grinding
Dame I wish I hadn't allready paid for the pro comp heads and got the edelbrock ones from the states
shmeagain
Re: testing is 50 on sunday
Post by shmeagain »
ITS SHMEAGAIN HAPPY 50th birthday for sunday
